Page 2 of 2 FirstFirst 12
Results 11 to 11 of 11
Saturation test of a 1500/5 multi-ratio CT
    #11
    Apr 2021
    31
    Quote Originally Posted by Tseppish View Post
    During a saturation test of a 1500/5 multi-ratio CT, 400 volts is applied to the X1 to X4 tap. The X1 to X4 tap is the 1200/5 ratio. What is the expected voltage across the X1 to X5 tap?
    Correct answer is 0 Volts.
    Can we have clarification on what the question is suggesting? Are you applying 440 V directly on the taps? Aren't the X4 and X5 taps the same point, electrically, and would therefore have the same potential voltage?
    My initial reaction was that the answer would be correct, but after drawing it out, now I am not so sure. I would definitely not say that it's the same point electrically, because we are dealing with AC as oppose to DC, so the fact that the coil of wire acts similar to a resistor with AC, it would be reasonable to have a difference in voltage of some kind. If they were the same point electrically, then you could say the same about X1 and X4, really.
    Now, I am actually surprised that the voltage would not be higher than what was injected, because I would assume the CT to essentially act as an auto transformer, since it is one continuous piece of wire. Also, some other comments mentioned that they even tried it, and was able to read a voltage, so my instinct says the answer is wrong, but I am willing to be convinced otherwise.
  1. What is the turns ratio?
    By franko26 in forum NETA Level 2 Exam
    Last Post: July 10, 2018, 03:41 PM
  2. Problem running ratio test with Megger multitap CT test set
    By ejbrewer in forum Electrical Testing Talk
    Last Post: June 30, 2016, 03:13 AM
