MRCT test set giving -36% error
  1. tcoupekyle is offline Member Pro Subscriber
    Aug 2021
    C100 800:5 ct
    Using MRCT test set.
    Provides a -36% error and no matter which way I flip the leads it always says the polarity is correct.
    Anyone run into this?
    Thanks
  3. tcoupekyle is offline Member Pro Subscriber
    Aug 2021
    Quote Originally Posted by tcoupekyle View Post
    C100 800:5 ct
    Thanks
    Turns out, test set was bad
    Quick way to test Ratio is accurate is connect H1 and X1, and connect H2 with X2. Run only ratio test and Ratio will be 1. Same with TTR.
  7. tcoupekyle is offline Member Pro Subscriber
    Aug 2021
    We did that and everything came out ok. Then we retested with same issue. Then the MRCT would no longer operate at all via computer or the front panel. So got an ez ct and everything worked out.
  1. What is the percent error?
    By papiLG in forum NETA Level 2 Exam
    Last Post: November 6, 2021, 07:02 PM
  2. Megger error 10
    By DeAlba in forum Electrical Testing Talk
    Last Post: September 29, 2021, 11:58 AM
  3. Megger Insulation Tester 'UNC' Error
    By websterd in forum Electrical Testing Talk
    Last Post: January 13, 2020, 03:54 PM
  4. Help with calculating percent error
    By trhea@saberpower.com in forum NETA Level 2 Exam
    Last Post: October 24, 2017, 05:21 PM
