Results 1 to 10 of 10
ANSI Numbers help
  1. cnowak is offline Junior Member
    Jun 2021
    18
    ANSI Numbers help
    I know there is no easy way to remember all of the ANSI numbers that would be found on the NETA 2 test. However if anyone has any tips or tricks to help you remember any of them I would be greatly appreciative.
    502
    Quote Originally Posted by cnowak View Post
    Practice them every day. TestGuy has a "ANSI Device Numbers" tech quiz that is good for drilling. You can also ask your co-workers to quiz you and make a game of it on the job.
  5. cnowak is offline Junior Member
    Jun 2021
    18
    Thanks, I've tried the practice test. It would be good practice if I already knew most of the ANSI numbers however it definitely is not a good place to learn the ANSI numbers.
  7. rofo42 is offline Seasoned Member
    56
    I bought index cards and made flash cards out of them. Everyday I would go through them a couple times. Pure repetition is the only way for me to learn stuff like that.
    It also helps to use prints on a daily/weekly basis for your job that incorporate these but you may not have that in your current stage of your career.
  9. cnowak is offline Junior Member
    Jun 2021
    18
    I also have cards and am practicing them. However I was really wondering if there were any sayings that help individuals remember specific numbers.
  11. rofo42 is offline Seasoned Member
    56
    "Repetition makes a technician"
    All I can come up with right now 🙂
    Jul 2020
    Washington, United State
    44
    try to save common ones like:
    21,24,25,27,32,37,47,50,51,52,59,67,76,81,86,87
  15. cnowak is offline Junior Member
    Jun 2021
    18
    Quote Originally Posted by Izeldeen View Post
    Thank you. I think I'm going to try and write them down over and over again. Kind of like elementary school vocabulary. Hopefully that works out for me.
    Jul 2020
    44
    sure, should be work.
  19. alf583 is offline Junior Member Pro Subscriber
    Sep 2021
    8
    For something like this, flashcards are my jam.
    I also found whittling the stack down as you learn helps zero in on the trouble ones, builds confidence, and saves time.
    So as you begin to memorize them, for example you get it immediately correct 3ish times in a row, take that card out of the stack and set it aside.
    Then every few rounds through the stack add them back, then whittle them out again as needed.
    This helps hammer the tougher ones and reinforce the easy ones.
    I've used this method for oodles of written and oral exams.
    Hope this helps.
  1. ANSI Rule of Thumb for Transformer Polarity
    By bec51392 in forum NETA Level 3 Exam
    Last Post: October 25, 2021, 11:04 PM
  2. most important device numbers to remember
    By Dfurrer2 in forum NETA Level 2 Exam
    Last Post: December 12, 2020, 08:08 AM
  3. ANSI Device Numbers
    By demtxboyz in forum NETA Level 2 Exam
    Last Post: April 20, 2020, 06:39 AM
  4. ANSI/IEEE Device Numbers on NETA II Exam
    By Bob_Woodward in forum NETA Level 2 Exam
    Last Post: August 21, 2019, 10:07 AM
