Page 2 of 3 FirstFirst 123 LastLast
Results 11 to 20 of 24
Remembered NETA 2 Questions Help
    #11
    Jul 2021
    I agree
    I'm thinking motor should stop and stay at highest level. A?
    I agree! After speaking to other technicians in my company and reaching out to a XFMR OLTC Manufacturer, they stated A should be the correct answer.
  2. #12
    Jul 2021
    No Title
    This is usually fairly obvious by the jacket, any guesses on answer options?
    I can't remember the exact answers. If I recall I think one of the answers had to do with the termination type, and one answer also had to do with the cable type (THHN, THWN). Both of those cable types would be associated with LV cables and not fiber cables correct? Thank you again for your input on this question! @SecondGen
  4. #13
  5. SecondGen's Avatar
    487
    Quote Originally Posted by A_Powers1992 View Post
    I would suspect some reference to a connector or what is written on the jacket as you have stated. Fiber optic cables are typically very thin and have a bright orange jacket.
    THHN, THWN would be 600V rated cable. Anything with a twist type or plug connector would most likely be fiber optic as control wires typically land on a screw terminal of some kind.
  6. #14
  7. michaellabeit is offline Junior Member Pro Subscriber
    Apr 2020
    4.) Which XFMR test has the ability to magnetize the windings?
    a.) Power Factor
    b.) TTR
    c.) Excitiation
    d.) Zero sequence impedance
    I would usually say Winding Resistance but it was not one of my choices.
    AP
    My understanding is that excitation tests magnetize the CTs. This Testguy article from 2017 says the following:
    "Excitation tests are performed by applying an AC voltage to the secondary winding of the CT and increasing the voltage in steps until the CT is in saturation. The "Knee" point is determined by observing a small voltage increase causing a large increase in current.
    The test voltage is slowly decreased to zero to de‐magnetize the CT. The test results are plotted on a logarithmic (log‐log) graph and evaluated based on the transition period between normal operation and saturation."
    Winding resistance tests also magnetize the CTs, but that's not one of the answers.
  8. #15
  9. SecondGen's Avatar
    487
    Quote Originally Posted by michaellabeit View Post
    I wasn't even thinking about current transformers but you are correct in that case. My assumption was PF and excitation were referring to the same thing but they could be talking about CT's.
  10. #16
    Mar 2020
    Not alot of experience
    I have only been out out of the navy for 2 years (ish) but typically Ive been seeing orange jacket on fiber opt. cable.
  12. #17
    Aug 2021
    5.) A Multimeter is device that:
    a.) is connected in series, low impedance
    b.) is connected in series, high impedance
    c.) is connected parallel, low impedance
    d.) is connected parallel, high impedance
    6.) What is the highest pickup for a low voltage-480 system ground?
    a.) 600 A
    b.) 800 A
    c.) 1000 A
    d.) 1200 A
    Both 5 and 6 are d.
    Multimeters are high impedance in parallel, so the impedance of the multimeter does not effect the measured device (think about current through parallel resistors, almost no current will flow through one that is sufficiently larger than the other). This only applies to voltage measurements though. Current would be the inverse if you don't have a clamp on meter and were measuring current in series however, so it's weird they worded it like that. I'm just assuming they're referring to a voltmeter.
    I've seen a lot of settings lately and they will not let you set the GF greater than 1200A. This is in NEC 230.95 (a) (I'm using 2017, I don't believe the wording has changed though)
  14. #18
  15. bec51392 is offline NETA Level II Pro Subscriber
    Dec 2019
    Richmond VA
    33
    This could be b, c, or d but NEMA 4 would offer the most protection.
    https://testguy.net/content/158-NEMA...ical-Equipment
    from my contractor days R is outdoor. stands for rainproof
  16. #19
  17. bec51392 is offline NETA Level II Pro Subscriber
    Dec 2019
    Richmond VA
    33
    Usually the flag just tells you the last position in which the mechanical switch was operated and nothing more.
    When I first read this question I assumed "flag" was a light... and a light could mean control power was still proper.
  18. #20
  19. bec51392 is offline NETA Level II Pro Subscriber
    Dec 2019
    Richmond VA
    33
    1.) What is the small notch in a fuse for?
    rejection notch, keeps you from installing an improperly rated fuse
    "A rejection feature is used to prevent fuses with a lower voltage or interrupting rating (such as Class H and Midget fuses) from being used in a circuit that needs a higher rating. Class R and CC fuseblocks incorporate a built-in rejection feature while Class J and T blocks reject based on physical size"
    a.) 600 A
    b.) 800 A
    c.) 1000 A
    d.) 1200 A
    NEC Paragraph 230-95(a) specifies the maximum ground fault protection setting to be 1,200 amperes
    7.) Why do an insulation test between neutral and ground?
    gotta confirm its only grounded in one spot and that its the proper spot
    10.) Testing motor circuits would best be achieved by use of?
    a.) Ohmmeter
    b.) Phase-angle meter
    c.) Ammeter
    d.) ???
    are you certain this is worded right?
    11.) What is the standard for testing UPS Batteries?
    This could be taken a couple ways. Was the question what is the IEEE standard? I would say 1184.... but there are a few different IEEE standards that NETA points to depending on type.
    supposedly nfpa 855 also has some info, but I haven't personally looked
    12.) What are considered Network Protectors?
    I think I got this question. Is it supposed to read "what do network protectors consist of?"?
    13.) You arrive to find a MV circuit breaker open. At the control panel in the adjacent room you see the mechanical switch open with a red flag. What would this indicate?
    a.) The breaker lost control power
    b.) The breaker was opened at the control panel
    pretty sure this is b
    14.) What is the outdoor panel class?
    a.) Class 2
    b.) Class 3
    c.) Class 3R
    4.) Class 4
    3R, R stands for Rainproof.
    15.) How can you recognize the difference between fiber optic cables and insulated cables?
    cut em' in half and look inside! kidding. I think its the jacket
    16.) What type of switch is best used for commercial/light industrial services rated 2000/4000 A?
    a.) safety switch
    b.) metal enclosed interrupter
    c.) bolted-pressure switch
    d.) ??
    Im pretty sure this is bolted pressure switch. I think safety switches max out at 1200
    There is a testguy write up on it somewhere that I vaguely remember reading. I'll try to find it.
  1. NETA 4 exam questions I am unsure about
    By mmacdonell in forum NETA Level 4 Exam
    Last Post: August 6, 2021, 07:15 AM
  2. NETA 4 Exam Questions 7/2018
    By MartyCoyne in forum NETA Level 4 Exam
    Last Post: February 25, 2021, 12:27 PM
  3. Why so few questions for NETA 4 exam?
    Last Post: February 10, 2020, 12:14 PM
  4. Challenging NETA questions after the test
    By adamstraub in forum NETA Level 3 Exam
    Last Post: October 24, 2019, 07:38 AM
  5. Couple NETA III Questions
    By jaycee91 in forum NETA Level 3 Exam
    Last Post: January 23, 2019, 01:14 PM
