Testing 3 phase fan motors
    Jul 2021
    Tyson, VA
    I'm unsure how to check if this particular motor is good/bad. I've tried searching online on how to test motors such as this but nothing I can find relates to what we have. I believe this is a delta config motor but unsure. I've provided the schematic and picture of the device if any has experience with this please let me know!
    I want to be able to check the winding resistances. Thanks guys!
    Attached Files Attached Files
  3. RabbleRabble is offline Junior Member Pro Subscriber
    Apr 2020
    24
    Quote Originally Posted by Jonsailor View Post
    I dont know this for a fact but. It looks like a motor with an integrated speed controller. A pot 1k to 10k and a 10v DC power supply may be needed. If that works dont forget not to exceed 2A when taking the readings.
    Jul 2021
    Tyson, VA
    Quote Originally Posted by RabbleRabble View Post
    Thanks.
    I just learned this device comes with a controller that connects to the terminals and provides a diagnosis. I wanted to check if there was a way to get a winding resistance from the motor itself.
    485
    To check winding resistance, you would disconnect the motor from the controller and measure directly across the motor windings. All you are doing is applying a DC current across the winding and measuring the voltage drop at each end. Use the max current the motor can handle, up to 10A. The more current, the more accurate reading.
  9. RabbleRabble is offline Junior Member Pro Subscriber
    Apr 2020
    24
    Thanks.
    Were you able to take the resistance readings you needed? I wondered if it was a brusless DC motor. I cant real everything in the pick you posted.
  1. What kind of motors are protected by power factor relays
    By mcmahanrf in forum NETA Level 4 Exam
    Last Post: June 23, 2021, 08:15 AM
  2. What is the best TTR for 3 phase transformers?
    By Robertsj in forum Electrical Testing Talk
    Last Post: October 9, 2020, 03:36 PM
  3. Field Testing of Motors, IEEE 43
    By SecondGen in forum NETA Level 3 Exam
    Last Post: September 5, 2020, 10:20 PM
  4. How much is the alternator phase current?
    By clayton in forum NETA Level 3 Exam
    Last Post: March 21, 2019, 05:35 PM
  5. Phase Sequence Relay Testing (Tengen XJ3-G)
    By lnides in forum P&C / Relay Testing Talk
    Last Post: May 30, 2016, 03:25 PM
