Breaker is timing at 10 cycles slower than nameplate
    30
    If a breaker is timing at 10 cycles slower than nameplate and 2nd time it is 4 cycles slower, what is the best course of action next?
    Your Answer: Breaker needs to be marked bad and removed from service
    WRONG
    I heard you should not use lub. but send it for repair. lub is just a temp fix!
    Sep 2018
    Quote Originally Posted by akumaleon View Post
    WRONG
    Every breaker has lubrication in it, different parts get different lubrication and also varies by manufacturer. The question suggests that the breaker gets faster with each operation, so lubrication and exercise would be recommended. If a company wasn't qualified then they should send it for repair, where another company will lube and exercise it.
    Jan 2021
    21
    spray lube on the bearings is the wrong answer too
    WRONG
    30
    make it within tolerance
    Operate until it falls within tolerance (correct answer)
    Spray lube on the bearings
    Use penetrating lube on the bearings
  1. Number of cycles completed in one second
    By RabbleRabble in forum NETA Level 2 Exam
    Last Post: November 29, 2020, 02:00 PM
  2. Looking for a circuit breaker timing analyzer
    By Spirol_ttc in forum Electrical Testing Talk
    Last Post: August 10, 2020, 11:22 AM
  3. VCB Contact Timing Test (11KV)
    By shamimkhan in forum Electrical Testing Talk
    Last Post: January 2, 2019, 08:36 PM
  4. CL protective device cycles?
    By Havik21 in forum NETA Level 4 Exam
    Last Post: November 2, 2018, 12:36 PM
