Results 1 to 10 of 11
Sponsored by
Doble M4000 Temp Sensor Help
    502
    Looking to repair our M4000 temp/humidity sensor cable, can anyone help with the pinouts? Connector pins are labeled 1-4, need to know which color goes to which pin.
  3. gchoquette is offline Junior Member Pro Subscriber
    Mar 2019
    22
    Internal components are very cheap to replace
    Hi, I don't remember the pinouts, but if ever the unit goes bad, it's usually either the thermistor or the humidity sensor. Doble (if I remember well) sells replacements for around $1,600 and the thermistor is $1.00 and the humidity sensor is around $10. There's a part number on the humidity sensor and that's the one that usually goes bad. The thermistor does not have a part number, but I figured it out my measuring it's resistance at two temperatures and found some with matching specs.
    The sensor communicates with the main unit serially, so you won't damage anything by just trying several of possible combinations.
    Good luck.
    30
    Probe pin out
    Quote Originally Posted by gchoquette View Post
    Good luck.
    If I recall I believe it looks like this!
  7. rofo42 is offline Seasoned Member
    56
    Just checked my test set for you.
    Red > 1
    Silver > 2
    Black > 3
    Green > 4
    30
    Red > 1
    Silver > 2
    Black > 3
    Green > 4
    was 5 a shield ?
    502
    Thanks for all of the responses, hopefully its just the cable and I can find some time by end of the week to get this thing fixed. Looks like the terminals on the connector are really small, its going to be a trick to solder.
  13. rofo42 is offline Seasoned Member
    56
    Those devices go bad quite often from what I have seen. I hate to say it, but the cable is probably not the issue. Just saw a bad weather sensor last week, actually.
  15. Kalbi_Rob's Avatar
    262
    In the meantime,
    If you didn't already figure it out, you can bypass the temperature sensor in the DTA settings. We had a tech leave it on a transformer thru a week of thunderstorms and had to have it replaced (sitting full of water destroyed it), but we found out he left it when we went to use it and it was missing.
    Luckily, I always carry a cWheap temperature/humidity gauge I bought at Home Depot to use to input manually into DTA.
  17. SecondGen's Avatar
    502
    Good luck.
    So, we tried the pinouts suggested in the thread and now the sensor gives us crazy high temperature (200C) and no humidity. Either we got the pinouts wrong or the sensor is bad. I need to get my hands on another cable to be sure but next step would be replacing the sensors.
  19. SecondGen's Avatar
    502
    In the meantime,
    Thanks Rob. We've been bypassing the sensor in DTA for quite sometime now and also use external meters but I thought it would be nice to get this thing working after an easy fix - so far no luck.
  1. Doble Testing a Bushing: C2 reading higher than nameplate
    By Bob_Woodward in forum Electrical Testing Talk
    Last Post: November 17, 2021, 08:37 AM
  2. Doble Protection Suite F6150e Setting
    By ACOUNDOUL in forum P&C / Relay Testing Talk
    Last Post: March 4, 2020, 09:24 AM
  3. Doble Protection Suite F6150e Prefault Voltage, Current, Angle
    Last Post: February 21, 2020, 11:02 AM
