Results 1 to 8 of 8
What are the magnitude and direction?
    Sep 2019
    If a = (5, -12), what are the magnitude and direction of a?
    The above question marked me wrong I answered:
    (13, 292.6°)
    I double checked this online and my answer was correct
  3. Uguessus is offline Junior Member Pro Subscriber
    Dec 2019
    Signal Hill, CA
    Quote Originally Posted by csabin View Post
    (13, 292.6°)
    I calculated (13, 337deg). Here is what I have for the angle...270deg + 67deg = 337deg.
  5. csabin is offline Junior Member
    Sep 2019
    Quote Originally Posted by Uguessus View Post
    I even went back to a calculator website. The angle should be 360-67.3 = 292.7 degrees because if you think of this even logically the vector would have to be closer to the y axis much closer to 270 degrees. Due to the fact that -12 is much larger then 5.
    Also you can even prove this with a calculation arctan(-12/5) = -67.3 degrees. I’m 1000% positive this is an error on test guide or I have wrote the problem wrong.
  7. Uguessus is offline Junior Member Pro Subscriber
    Dec 2019
    Signal Hill, CA
    You are right. I made a big mistake on where I should add or deduct the 67deg, 292Deg is right.
  9. Kalbi_Rob's Avatar
    290
    Always make a visual verification that you are in the right quadrant using the (X,Y) as a basis for your final answer.
  11. Uguessus is offline Junior Member Pro Subscriber
    Dec 2019
    Signal Hill, CA
    That's a good point. Thanks.
    Apr 2021
    32
    Update Question Please
    Any way the moderators may be able to update this question to the correct answer? I also got it marked wrong, and came up with the same answer deemed correct in this forum topic.
    Apr 2010
    558
    Quote Originally Posted by bob152637485 View Post
    Thanks for reporting, someone will take a look.
