Results 1 to 10 of 12
Number of cycles completed in one second
    Apr 2020
    2. The number of cycles completed in one second is called the
    Your Answer: hertz
    marked incorrect
    Hertz A unit of measure for frequency. Replacing the earlier term of cycle per second (cps).
    Definition from this web site.
  3. jerrevd is offline Junior Member Pro Subscriber
    Jun 2020
    Quote Originally Posted by RabbleRabble View Post
    Your Answer: hertz
    marked incorrect
    Correct answer is "frequency", not "hertz"
  5. Kalbi_Rob's Avatar
    Kalbi_Rob is online now Experienced Member Pro Subscriber
    Richmond, VA
    185
    Your Answer: hertz
    marked incorrect
    jerrevd is correct:
    Frequency The number of cycles per second. Measured in Hertz. If a current completes one cycle per second, then the frequency is 1 Hz; 60 cycles per second equals 60 Hz.
    Hertz is a unit of measurement.
    Apr 2020
    jerrevd is correct:
    Frequency is the rate at which something occurs or is repeated over a particular period of time or in a given sample. It is not the rate at which something occurs "per second" unless further explained as such. If you read the question It specifically calls out a defined time of one second. Were frequency can be expressed in any amount of time. EX: the frequency of (cycles per min) equals 3600. the frequency of (cycles per second) equals 60.
    My point is the denominator when defining frequency is a variable not one second. The denominator in the unit Hz is defined as one second.
    Jun 2020
    Pakistan
    Power Produced in one complete cycle
    jerrevd is correct:
    Hi,
    I hope you are doing well. I am curious to know, how much power does a 2.5MW turbine would produce in one complete cycle? Will it be equal to 2.5MW?
    Apr 2020
    Quote Originally Posted by Waqas2121 View Post
    Hi,
    A ideal turbine running at 100% producing 2.5M W for one cycle at 60Hz. 2500000 216000= 11.57407 watt hours or 0.01157407 KWh. KWh is a common for expressing power over time. But it could be expressed as Watt (any measure of time).
    Apr 2020
    Thats not why you asked that tho is it. Were you making a point about cycles and frequency?
  15. SecondGen's Avatar
    420
    Given that the question ends with the statement "the," it wouldn't make sense to say "the hertz" as it would to say "the frequency." Try not to overthink the question and go with what makes sense.
    Jun 2020
    Pakistan
    Why you divided it by 216000? I mean it is what quantity?
    Apr 2020
    You asked a question about power over time. 60Hz = 60cycles per second. 60 seconds in one min 60 min in one hour. 60X60X60 = 216000 cycles per hour. So 2.5 MW for one hr = 2500 KWH. Divide that by 216000 gives you KW for one cycle at 60Hz.
  1. If a breaker is timing at 10 cycles slower than nameplate
    By akumaleon in forum NETA Level 3 Exam
    Last Post: February 25, 2020, 08:17 AM
  2. what is the number of questions you can miss on level 3?
    By Bbrown3664 in forum NETA Level 3 Exam
    Last Post: January 17, 2020, 10:43 AM
  3. Replies: 4
    Last Post: January 15, 2020, 03:54 PM
  4. CL protective device cycles?
    By Havik21 in forum NETA Level 4 Exam
    Last Post: November 2, 2018, 12:36 PM
  5. Test your ANSI device number knowledge with our all new quiz!
    Last Post: July 1, 2014, 06:00 AM
