Page 2 of 2 FirstFirst 12
Results 11 to 14 of 14
NETA III Test Feb 2020
    #11
  1. clipboardwarrior's Avatar
    clipboardwarrior is offline Junior Member Pro Subscriber
    Mar 2018
    13
    Do you remember if "high transient currents" was an option?
    I don't. I remembered as much as I could, but I was so stressed out. I'm surprised I remembered as much as I did.
  2. #12
    Jan 2021
    26
    help me out on this one
    What is the benefit of a synchronous motor?
  4. #13
  5. gchoquette is offline Junior Member Pro Subscriber
    Mar 2019
    22
    Quote Originally Posted by clipboardwarrior View Post
    Where do you bond the neutral to ground in service switchgear: before or after the neutral disconnect link?
    What would happen if you were to place the ground fault relay ahead of the N-G bond?
    According to Figure 1 and Figure 2 in the link below, the bond would be before the neutral disconnect.
    The ground fault relay CT is also before the neutral disconnect (Figure 1), but a zero sequence CT (combining all phases) is placed after the neutral disconnect (Figure 2).
    In response to the question, the N-G bond is solid and at the bottom of the service switchgear. It would be difficult to place the relay CT before (from ground as the reference), the CT is normally after (unless you are using a different frame of reference).
    https://electrical-engineering-porta...-ground-faults
  6. #14
  7. Warrengarber's Avatar
    Warrengarber is offline
    Seasoned Member
    Jul 2017
    Jacksonville, FL
    62
    High Harmonic Loads Causing Power Loss
    One of the other members posted some questions that he remembered from his exam. One of the questions was
    "You're troubleshooting in a building with a lot of high harmonic loads. They've been losing power. What is the most likely cause? (Sorry, I can't remember all of the symptoms.)"
    I know that high harmonics are seen on the Neutral so would that be an answer? Could cause problems with neutral sensors or ground fault tripping. Any thoughts. My exam is at the end of next month so I am getting ready again.
    Warren Garber
    Have a great day!
  1. Just failed my NETA Level 2 Test
    By dvansick2345 in forum NETA Level 2 Exam
    Last Post: January 31, 2019, 02:19 PM
  2. NETA Test Decal
    Last Post: July 10, 2018, 07:27 PM
  3. NETA II test 7/13/2016 is different
    By Bradfoxthelegend in forum NETA Level 2 Exam
    Last Post: September 27, 2017, 02:45 PM
