Results 1 to 8 of 8
Impedance of parallel inductors in series with parallel capacitors
    11. Two 1mH inductors are connected in parallel and in series with two 45uF capacitors connected in parallel. What is the total impedance of the circuit?
    Quote Originally Posted by slts1991 View Post
    11. 0.41 miliohms
    How did you come up with 0.41 milliohms? I don't see how to solve this without frequency to calculate reactance, assuming 60hz this is what i got
    1mH = 2x 377 ohms in parallel= 188.50 ohms
    45uF = 2x 58.9 ohms in parallel = 29.45 ohms
    series 188.50 + 29.45 = 217.95 ohms
    help?
    Feb 2015
    Quote Originally Posted by Inglefles897 View Post
    help?
    It is 188.50 - 29.45 because they are 180 degrees apart in a 60 HZ system and when connected in series they subtract from each other. When they are in series the formula is Z = XL - XC. In parallel the formula is more complicated and is similar to R1xR2/(R1+R2). In this case it is (XL*-XC)/(XL-XC). This means that as XL-XC approach zero (resonance frequency) that the impedance of the parallel tank circuit will approach infinity at that resonant frequency, but since the reactor and capacitor have watt losses you will never get infinity and real world examples of a wave trap have been 2000 to 10000 ohms at resonant frequency. A wave trap blocks the resonant frequency from getting onto the operating bus and passes the 60 HZ, so a wave trap has to be rated to carry normal line loads. Your series resonant circuits are similar and we call those line tuners in the power line carrier world. As XL-XC approach resonant frequency the two cancel themselves out and it allows your resonant frequency to pass and it blocks your carrier frequency.
    Resonant Frequency equals 1/(2 PI (LC)^.5). I know that this formula is not needed for the above mentioned problem, but it helps you understand why a problem like this may be important and helps you figure out what size capacitor and reactor is needed for a wave trap and line tuner.
    So, the answer to this problem is actually 159.05.
    My old Navy instructors told me that the Smithsonian had a tank circuit ran for decades and only seemed to lose power when they took measurements, but I but that was just an electronic legend, lol.
  5. mmacdonell is offline Junior Member Pro Subscriber
    May 2019
    17
    Quote Originally Posted by tonybeavers View Post
    How is everyone getting 377 ohms for XL?
    2 x 3.14 x 60 x .001H = 0.377 ohms, not 377 ohms???
    Jan 2019
    19
    Quote Originally Posted by mmacdonell View Post
    Not everyone! 0.377 is correct.
  9. SecondGen's Avatar
    I came up with something completely different from everyone else, someone please check my work:
    1. Inductors in parallel are halved:
    (2) 1mH inductors in parallel = 0.5mH = 0.0005H
    Xl = 2*pi*60*0.0005 = 0.1885 ohms
    2. Capacitors in parallel are additive:
    (2) 45uF capacitors in parallel = 90 uF = 0.00009F
    Xc = 1 / (2*pi*60*0.00009) = 29.473 ohms
    3. Subtract in series to get impedance:
    Zlc = Xc – Xl = 29.285 ohms
    I used this calculator to verify my answer: https://www.translatorscafe.com/unit...-lc-impedance/
    Jan 2019
    19
    Looks good. I think the issue I and others had was resolving the Xc of the caps and then mistakenly applying the 'caps in parallel' rules to the resultant reactance. Rather than finding the Xc of a single cap and then adding them together (wrong), you would then need to treat them as you would a resistor.
    As you did, finding the Xc of the resistors in parallel (adding capacitance together) is correct.
  13. jvlundquist is offline Junior Member Pro Subscriber
    Jan 2016
    All correct except #3. The formula for Zlc = squareroot of (Xl - Xc) in power of 2. The number came up really close but actually is 29. 288. Need to be careful, because is this case Xl is so small compare to Xc so not a significant difference in the result, but if the number would deviate a lot so would final impedance.
    Jan 2019
    19
    Quote Originally Posted by jvlundquist View Post
    XL and XC act along a straight line. Why would we take the squares?
  1. Ground Impedance Testing
    By africanamber in forum Electrical Testing Talk
    Last Post: October 18, 2018, 05:28 PM
  2. Proper connection for overcurrent relay with parallel CT's
    Last Post: October 21, 2017, 08:07 AM
  3. Total XC for capacitors in parallel
    By adamr8223 in forum NETA Level 3 Exam
    Last Post: December 4, 2016, 02:08 AM
  4. What is the circuit impedance?
    By Bradfoxthelegend in forum NETA Level 3 Exam
    Last Post: November 17, 2016, 03:16 PM
