Results 1 to 10 of 10
Blown fuse protective devices
    Nov 2019
    On which of the following pieces of equipment would you most likely NOT find a blown fuse protective device?
  3. Kmcphatter is offline Junior Member Pro Subscriber
    Feb 2019
    MCCB... Look at the other answers in that question. They are all fused...
    Quote Originally Posted by Balima View Post
  5. kchenoweth is offline Junior Member Pro Subscriber
    May 2018
    What are the choices?
    Mar 2020
    Quote Originally Posted by Kmcphatter View Post
    I answered MCCB and was counted incorrect, I don't recall all the answers. I believe it may be the 3000A bolted CB?
    Mar 2020
    Quote Originally Posted by Akumanchik View Post
    apperently it is not the 3000A CB either
    245
    Which of the following is LEAST likely to contain a blown fuse trip device? Ans.
    A. molded case circuit breaker
    B. 360 amp 4.16 KV motor starter
    C. low voltage power circuit breaker
    D. 200 amp fused safety switch
    E. none of the above
    According to this question saved by our question database, D) 200A Fused Safety Switch is the answer
    which makes sense, since the safety switch would typically be upstream of other devices, making it less likely to blow.
    487
    Agree, its doubtful you will find a blown fuse protection device on a tiny 200A fused safety switch. Finding them on MCCB's is probably becoming less-common as well.
    May 2020
    All the other devices could have (but don't have to use fuses) fuses. I have never seen a fuse used with a Molded case breaker. So, the Molded case breaker should be the answer.
  17. SecondGen's Avatar
    487
    Quote Originally Posted by fdotson View Post
    Look up Tri-Pac molded case breakers. Just because you haven't seen it doesn't mean it doesn't exist.
  19. TestingProToBe is offline Junior Member Pro Subscriber
    This was a tricky one! I missed it because of the wording, now that I look at it again it makes sense. Here is my thinking.
    Fused disconnects donít have electrical trips, at least I havenít seen one, only breakers do. So with that info right there the fusable disconnect makes the most sense.
