Results 1 to 10 of 15
What’s the best way to operate power dB
  1. TrapFlyVenus's Avatar
    TrapFlyVenus is offline Junior Member Pro Subscriber
    Dec 2018
    10
    What do you guys use for computers and the best way to set up power dB without failing? Operating this system is awesome...when it works. Either having trouble with devices connecting or power db itself shutting down.
    384
    Quote Originally Posted by TrapFlyVenus View Post
    My personal recommendation would be an i7 with 16GB RAM and dedicated gpu running win 10. Latest DB version is 11.2.8.4
    We just started integrating our compatible instruments with DB and so far so good. The delta 4k power factor set works great.
  5. TrapFlyVenus's Avatar
    Dec 2018
    10
    I’ll check my updates could be it. I’m running an i3 but used to be able to run everything (meager wise) on a transformer test without a problem just recently acting up had to restart whole computer for it to read my driver
    384
    What version are you running? A large database can eat up nearly 4GB RAM just in idle. How large is your db file? Maybe try reinstalling the drivers for the instrument.
  9. TrapFlyVenus's Avatar
    Dec 2018
    10
    Have 11.2 but There is a new file from 11-15 for 11.2 downloading now and files are all under 1GB
  11. TrapFlyVenus's Avatar
    Dec 2018
    10
    Looks like there’s a new update from 11-15 that deals with the drivers
  13. SecondGen's Avatar
    384
    What version do you show after running the update?
    Jan 2020
    California, USA
    Thank you SecondGen for your recommendation. It is really helpful.
  17. SecondGen's Avatar
    384
    Quote Originally Posted by JuliaSmith View Post
    No problem. Just to reiterate, those recommended specs are for the Pro version running a large SQL database. If you are using Lite, Advanced, or have a moderate Pro installation using an access database, you can probably get away with 4GB RAM on an i5 or i3 machine.
    Dec 2017
    17
    megger and Powerdb
    When doing a PI using powerDB and an equipment suck as a 5kv megger; does anybody knows if you can actually select only the points(time/result) you are interested example minute 1, 2 and 10?
