Results 1 to 9 of 9
Questions and Topics I Remember From The NETA 2 Exam
  1. rofo42 is offline Seasoned Member
    65
    Hope this helps some of you. I took and passed the NETA II a few months ago and wrote this up shortly after. I believe it covers the NETA II test topics fairly well.
    Voltage drop across resistors in series and parallel
    Total resistance calculations in very basic circuits
    What is the total inductance? Series and parallel
    Ductor readings - which one is acceptable?
    A few pictures with items like a CT being pointed to and asking what it is
    Generator testing
    Basic ANSI device numbers (if you know 21,27,32,50,51,52,59,87 you should be covered)
    What is the purpose of the NEC?
    One line drawings in general
    Know how to find kVARs - Know your power triangle in general
    Know how to find power factor
    General knowledge of power factor testing
    Ground testing (know the values in ohms)
    One or two questions on fiber optics
    Know the value (%) in which fuses fail
    Basics of thermography (emissivity etc)
    Electrical rubber glove classes (max use voltage) and inspection dates
    Of course, read your MTS and ATS! Quite a few questions lifted straight from those two. My test focused mainly on medium voltage testing requirements.
    NEMA enclosure ratings
    Familiarize yourself with anti pump characteristics
    Blow out coils
    Differential relaying theory (basics)
    “When is it acceptable to wear cotton clothing?” In regards to voltage levels
    One or two questions on mechanical relays operation such as “pick up current was low, what setting needs to be moved” etc.
    % allowable for transformer winding resistance
    Know what properties transformer oil shows when it has arced / broke down
  3. JamesM is offline Junior Member Pro Subscriber
    Aug 2018
    Thank you!
    I took my first practice quiz today and was furiously writing down the things I didn't know.
  5. chrisstewart is offline Junior Member Pro Subscriber
    Jul 2019
    Thank you for such a comprehensive list!
    What do you mean by "Ground Testing (Know the values in ohms)"?
    Generator testing
    Blow out coils
  7. rofo42 is offline Seasoned Member
    65
    Quote Originally Posted by chrisstewart View Post
    From the Paul Gill book, page 688.
  9. chrisstewart is offline Junior Member Pro Subscriber
    Jul 2019
    Thanks!
  11. chrisstewart is offline Junior Member Pro Subscriber
    Jul 2019
    Do you know where to find the answer to:
    Generator testing
    Blow out coils
  13. rofo42 is offline Seasoned Member
    65
    I can't remember the answers options but these might help.
    https://www.osha.gov/SLTC/etools/ele...tclothing.html
    https://testguy.net/threads/2750-Lay...-It-Acceptable
  15. dacow22 is offline Junior Member Pro Subscriber
    Jul 2019
    Took my test today..
    Generator testing
    Blow out coils
    This was a helpful write-up. I took my test today and passed. Just a few math problems but most things came from the ATS/MTS book. I had a lot of medium voltage questions. I think if you've been in the field, practicing NETA testing for the recommended amount of time, you should be good. A lot of basic knowledge questions. One word of advice that helps the most, cancel out the known wrong answers. This help immensely.
  17. NBatson's Avatar
    NBatson is offline
    I NETA BREAK
    Feb 2019
    TX Gulf Coast
    19
    This is by far the most useful Neta Exam post I’ve seen this year. Thanks!
  1. NETA 4 Exam Questions 1/2017
    By ddd675 in forum NETA Level 4 Exam
    Last Post: December 8, 2020, 08:42 AM
  2. Transformer Exam Questions, NETA Level 2
    By adamstraub in forum NETA Level 2 Exam
    Last Post: January 17, 2019, 01:27 PM
  3. Neta 3 Exam pointers and questions
    By Zepold72 in forum NETA Level 3 Exam
    Last Post: April 29, 2016, 05:25 PM
  4. Official NETA Level 2 Exam Most Missed Questions, Spring 2000
    Last Post: March 16, 2016, 08:18 PM
  5. Read before posting any safety topics!
    By testguy in forum Safety and Arc Flash Talk
    Last Post: April 22, 2014, 09:36 AM
