Metering Percent of Accuracy
    May 2016
    A given voltmeter has an accuracy of 7.5% and can read 150V at full scale, what could be said for such meter?
    So wouldnt it be at any range still same %?
  3. Warrengarber's Avatar
    Warrengarber is offline
    Seasoned Member
    Jul 2017
    Jacksonville, FL
    62
    I am not sure what the choices were for the question but you can probably expect that given the information that is talking about an analog meter. If the meter is 7.5% off at full scale then it is not very accurate at lower readings of full scale. If the meter is off by 7.5% at 150v, full scale, then if a target is 150v the meter could read as high as 161.25 or as low as 138.75. The 11.25v delta is constant through the voltage scale so reading a 100v target you could read 88.75v to 111.25v and still be in the accuracy of the meter. So if you are trying to read a voltage of something that is only 20v your deviation could be greater then 50% and still be within the accuracy of the meter.
    The rule is to get the most accurate reading you should stay in the upper 2/3 of your scale. I am not sure if that helps but that is the way it was explained to me.
    Quote Originally Posted by rasilva View Post
    Warren Garber
    Have a great day!
    Houston, TX
    Warren is absolutely correct.
    Jul 2018
    Just seen this question as 7.5% At full scale. Would be 7.5/.5 At half scale 15%err or 7.5/.75 for Three quarter scale 10%err
  1. How accurate is the testguy practice test?
    By JtotheJ in forum NETA Level 2 Exam
    Last Post: October 19, 2018, 04:44 PM
  2. Help with calculating percent error
    By trhea@saberpower.com in forum NETA Level 2 Exam
    Last Post: October 24, 2017, 05:21 PM
