Results 1 to 7 of 7
How much is the alternator phase current?
  1. clayton is offline Junior Member Pro Subscriber
    Feb 2019
    I have been stuck on this question and just can't seem to figure out how to get the correct answer of 6.93.
    Would you be able to show the work needed for this?
    Kalbi_Rob is offline Seasoned Member Pro Subscriber
    59
    Quote Originally Posted by clayton View Post
    Can you assist us by stating the question you need answering?
  5. clayton is offline Junior Member Pro Subscriber
    Feb 2019
    Ahh, well wouldn't that make a whole lot of sense. I guess I assumed people could read my mind
    A wye-connected alternator that has phase voltages of 277 V is feeding two loads. The first load is wye-connected inductors that have 40 ohms of XL. The second load is a set of delta-connected capacitors that have XC of 60 ohms. How much is the alternator phase current?
  7. Kalbi_Rob's Avatar
    59
    I can't help you, I only get 20.781 A. Now the current flowing through the Wye-connected inductors appears to be 6.93A. I have to ask if you might have misunderstood the question.
  9. J2019L is offline Junior Member Pro Subscriber
    May 2014
    Seattle, WA
    1. Convert Xc from delta connection to Y connection. In Y connection, Xc'= 60*60/(60+60+60)=20
    2. Calculate balance 3-phase circuit for two loads, parallel Xc' & XL. Total load 1/X= (1-2)j/40 --> X=40j (reactance)
    3. 3-Phase balance current I = 277/40 = 6.925 --Ans
  11. Kalbi_Rob's Avatar
    59
    Quote Originally Posted by Jimmy Lee View Post
    Aww, that's the equation I forgot
    Z=1/(sqrt((1/R)^2+((1/XL)-(1/XC))^2))
  13. J2019L is offline Junior Member Pro Subscriber
    May 2014
    Seattle, WA
    To solve this question, need to have math and electric concept. In the complex number, R represents real part and Xc, XL represent complex parts. So, R is the number on the real axis and Xc and XL are the number on the complex axis. Xc and XL are the number on complex axis, but XL is positive (to up side) Xc is negative (to down side) on the complex axis. Therefore, it is showed minus between (1/XL -1/Xc). And in this question R = 0, The equation becomes simplified Z = 1/sqrt((1/XL)-(1/XC))^2)
  1. alternator frequency????
    By lester mcmanaway in forum NETA Level 3 Exam
    Last Post: February 1, 2019, 12:05 AM
  2. 1 phase AC 115V 1 HP motor full load current calc.
    By davidb in forum NETA Level 2 Exam
    Last Post: May 2, 2018, 02:13 PM
  3. A phase-to-ground fault would primarily produce which type of current?
    Last Post: January 8, 2016, 11:14 AM
  4. Help understanding 3 phase electrical systems
    By randywright in forum Electrical Testing Talk
    Last Post: October 22, 2015, 11:46 AM
