Results 1 to 3 of 3
Watthour meter testing
  1. Larry5443's Avatar
    Larry5443 is offline
    Cabinet Rat Neta Level 4
    18
    Does anyone a procedure for testing watthour meter or can explain how to test them
  3. gasman is offline Junior Member
    Jun 2016
    Quote Originally Posted by Larry5443 View Post
    https://www.usbr.gov/power/data/fist...10/vol3-10.pdf
    Check also
    http://www.radianresearch.com/media.php#manuals
    Nov 2019
    #1-If you have a dedicated Whr test set it is easiest.
    #2-With a 3 Phase Relay Test set as a source and a separate reference meter will work well
    #3 Omicron has equipment that works quite well with various adaptors to sense IR/LED pulse or KYZ from meter and does not need a separate reference.
    #4 Old school, single phase "phantom load". A variac, large power resistor and reference meter.
    #5 The Radian equipment is well respected and the price reflects that. There are certain very high accuracy class meters that will require a Radian.
    You can rent all of the above equipment.
    The tests are (from memory)
    Full Load 100% Power Factor
    50% Load 100% Power Factor
    Light (10% of CT Sec) 100% Power Factor
    Full Load 50% Power Factor
    50% Load 50% Power Factor
    Light (10% of CT Sec) 50% Power Factor
    Typical Test Registers are 1.8
    DUT pulses are compared after a certain duration. Calculate % difference = 100- (% difference)=% Registration
  1. Klein Tools Clamp Meter Recall
    By madMAX in forum Safety and Arc Flash Talk
    Last Post: 1 Week Ago, 05:56 PM
  2. No current display when testing EATON IQ 100 panel meter
    Last Post: May 18, 2018, 06:27 PM
  3. watt-hour meter: finding revolutions per minute?
    By Bradfoxthelegend in forum NETA Level 3 Exam
    Last Post: January 18, 2018, 10:37 AM
  4. EATON PX2000 Meter: How to Change IP Address in Power Xpert
    Last Post: September 29, 2016, 05:07 PM
