What type of switch is required for an incoming service of 3000-4000A?
    Jan 2017
    I guessed (incorrectly) that the answer was a "metal enclosed isolation switch," and my rationale was mostly centered around the isolation aspect. Does anyone know of any sources I can read that can help clarify this? I'm guessing the correct answer was "bolted pressure switch" but I'm not sure why that's any more correct than the answer I gave, although I figure it's got something to do with the high current associated with the incoming service.
    Thanks!
    Oct 2018
    Quote Originally Posted by IncredibleGreg View Post
    Thanks!
    Metal Enclosed Interrupter Switch. That's what I've seen at facilities.
    Jan 2019
    Thanks!
    They are somewhat different in construction. Bolted one sort of acts like a bus and gives better reliability in a long run. That's why it's used for higher ratings
    Oct 2018
    Quote Originally Posted by akumar View Post
    I forgot to add: In Medium Voltage service equipment, these are Metal-Enclosed Interrupter.
    3000 - 4000 Amps has to be Low Voltage. So - Bolted Pressure Switch is the choice.
  9. Jrmcritical's Avatar
    Jrmcritical is offline
    NICET Level I (ID: 150100)
    NICET Level 1 Pro Subscriber
    Dec 2018
    West Fulton, NY
    15
    The answer would definitely be bolted pressure switch as its one of the few switches that can handle a high ampacity and be built to withstand a 200kAIC fault current.
  1. TTR on K type transformer
    By tallyson71 in forum Electrical Testing Talk
    Last Post: May 25, 2015, 12:23 PM
