Results 1 to 6 of 6
demagnetizing a XFMR
  1. jaycee91 is offline Junior Member Pro Subscriber
    Dec 2016
    how do you demagnetize a transformer?
  3. phasor's Avatar
    phasor is offline Junior Member Pro Subscriber
    Dec 2018
    13
    Quote Originally Posted by jaycee91 View Post
    Some winding resistance test sets have a demag function
  5. Behab1's Avatar
    Behab1 is offline Junior Member Pro Subscriber
    Mar 2015
    8
    Use a car battery and let the current flow through the winding.
  7. jaycee91 is offline Junior Member Pro Subscriber
    Dec 2016
    Quote Originally Posted by Behab1 View Post
    So DC current is the answer?
  9. Kalbi_Rob's Avatar
    Richmond, VA
    164
    AC or DC can be used. AC amps applied close to the excitation knee and slowly lowered can demag, and long tedious alternating of lowering DC currents can demag. Edit: I would highly recommend using AC
    Previous TestGuy thread about it:
    https://testguy.net/threads/2749-Cor...nsformer-cores
    Article on importance of demag xfmrs with AC explanation:
    https://www.tdworld.com/substations/...nsformer-cores
  11. SecondGen's Avatar
    411
    More like alternating DC, which is effectively AC - just not the 60Hz frequency you might be used to. You can use a car battery to pass current thru a winding in different directions, if you watch a winding resistance test set de-mag function you can see the process in action.
    An example would be something like this:
    +10A
    -10A
    +7A
    -7A
    +5A
    -5A
    +3A
    -3A
    +1A
    -1A
    This isn't exact by any means, I'm just trying to show an example. I'm sure you can also use regular AC voltage but a car battery was mentioned earlier and that's how I was originally taught. Also winding resistance sets usually operate off DC which is why the above method is used. As far as I understand you only need to perform this on one winding to de-mag a polyphase transformer.
  1. XFMR test question - wye-delta TTR
    By dbryce89 in forum NETA Level 2 Exam
    Last Post: March 13, 2019, 06:56 PM
