Results 1 to 2 of 2
Confusing question on NETA 2 practice test
    Jan 2017
    Hey all,
    I was taking the NETA 2 practice test when I encountered a question with what appeared to have two right answers. The question simply said "47" in reference to the IEEE device number, and the four answers were:
    Distance relay
    Directional relay
    Phase balance relay
    Phase sequence relay
    Power factor relay
    The correct answer, according to the IEEE device list I had printed off and sitting right next to me, is both phase balance and phase sequence. This was confirmed by the test itself a few questions later, with the question "Which of the following is the ANSI/IEEE device number for a phase-sequence or phase-balance relay?"
    I got the first question wrong by answering phase sequence (I think) but I got the second question right by answering "47." So my question is, was the first question somehow only one of the two options and I just guessed incorrectly? I'm not sure how that's possible but I wanted to be sure. Here is the device number list I was using as a reference. Is it, and the second question, wrong? http://www.ece.uidaho.edu/ee/power/E...ures/L3/L3.pdf
    Michigan
    40
    Quote Originally Posted by IncredibleGreg View Post
    Hey all,
    Distance relay
    Directional relay
    Phase balance relay
    Power factor relay
    ANSI 47 - Negative sequence over-voltage protection against phase unbalance resulting from phase inversion, unbalanced supply or distant fault, detected by the measurement of negative sequence voltage. Or, Protection against phase unbalance resulting from phase inversion, unbalanced supply or distant fault, detected by the measurement of negative sequence voltage
    This relay operates on the negative sequence voltage caused by voltage imbalance, reverse rotation, or combinations due to faults. In my experience, phase sequence is more common than phase balance as a descriptor as it measures/operates on negative sequence voltage caused by imbalance.
    I would have answered Phase Sequence Relay.
  1. Which relay is used to protect feeders?
    By EricGoetz92 in forum NETA Level 2 Exam
    Last Post: May 8, 2021, 09:14 AM
  2. Decreasing value of interfacial tension
    By EricGoetz92 in forum NETA Level 3 Exam
    Last Post: January 29, 2021, 07:16 AM
  3. Practice Test Question: Zone Interlocked Scheme
    Last Post: July 23, 2019, 07:35 PM
  4. Practice Test Question: Negative Sequence
    Last Post: June 14, 2018, 07:36 PM
  5. Practice Test Question: MC Cable Bend Radius
    Last Post: June 13, 2018, 02:58 PM
