Thermal imaging on overcurrent protective device
  1. MortalSnacks is offline Junior Member Pro Subscriber
    2. Thermal imaging is used by what type of overcurrent protective device (OCPD)?
  3. Kalbi_Rob's Avatar
    284
    Quote Originally Posted by MortalSnacks View Post
    a. Thermal-Magnetic
    b. Oil dashpot
    c. Digital/microprocessor
    d. Air Dashpot
    Answer: C. Digital/microprocessor
    Digital and microprocessor-controlled OCPD employ thermal imaging to mimic thermal memory that is characteristic of thermal bi-metal breakers.
    Source: Winter 2013 NETAWORLD Quiz
    Dec 2018
    Atlanta, GA
    27
    I guessed at this and got it right. I do thermal imagining and I know a microprocessor is needed to process the image.
  7. craiglamascus is offline Junior Member Pro Subscriber
    Apr 2022
    This Question/Answer do not make sense to me
    a. Thermal-Magnetic
    b. Oil dashpot
    d. Air Dashpot
    Can someone give me an example of an OCPD that uses thermal imaging? A manufacturer or part number?
    The answer seems to refer to a thermal model, not an image. Perhaps I just don't understand the wording.
  9. Kalbi_Rob's Avatar
    284
    Quote Originally Posted by craiglamascus View Post
    The function thermal imaging is not the same as say using a camera with thermal imaging. A couple of SqD functions utilizing Thermal Imaging to determine the cooling effect of the conductors:
    https://product-help.schneider-elect...unctions-6.htm
    https://product-help.schneider-elect...unctions-5.htm
    The control unit uses the calculation of a thermal image to evaluate the conductor heat rise and precisely monitor the thermal state of the conductors.
  1. IAC overcurrent relay, target and seal in coil
    By jflan13 in forum NETA Level 3 Exam
    Last Post: November 11, 2021, 09:23 PM
  2. Time Overcurrent Relay 51
    Last Post: December 6, 2019, 11:12 PM
  3. CL protective device cycles?
    By Havik21 in forum NETA Level 4 Exam
    Last Post: November 2, 2018, 12:36 PM
  4. Overcurrent protection
    By MartyCoyne in forum NETA Level 4 Exam
    Last Post: May 23, 2018, 01:24 PM
  5. Proper connection for overcurrent relay with parallel CT's
    Last Post: October 21, 2017, 08:07 AM
