Results 1 to 3 of 3
Ground Impedance Testing
    Aug 2018
    Hello - Our company purchased recently Omicron test set for us to perform Ground grid assessment, line impedance and Step and Touch. We have really only just begun the full capability of the test set, which works very nicely but had questions on Point to Point values and what is acceptable...I believe within a Substation of 115kv size, the ground impedance may only be required to be no more than 5 ohms, but I am not directly measuring the ground I am measuring from my reference point to another known point within our sub (Breaker GND, Switch GND and so forth). So what is actually permissible? We measured .5 milli ohms on average with injecting 100 amps, mind that the Sub is approx 300'X900'. I appreciate any comments regarding this Post. Thanks
    Dec 2015
    37
    Quote Originally Posted by africanamber View Post
    From what I can tell you are using the set for point-to-point DLRO at 100A to verify continuity between equipment. Average values of 0.5 milliohms (500 microhms) are good numbers in my opinion. Depending on the distance between equipment higher readings may still be acceptable.
    Aug 2018
    Thanks
    Thank you Sanjayo. I appreciate your input.
  1. Looking for chart on soil types for ground resistance testing
    By madMAX in forum Electrical Testing Talk
    Last Post: June 27, 2018, 12:49 PM
  2. Ground Resistance Testing IT System
    By rig-electrician in forum Electrical Testing Talk
    Last Post: August 13, 2017, 07:56 AM
  3. Testing ground resistance with no earth to drive rods
    By iwanttotest in forum Electrical Testing Talk
    Last Post: February 23, 2017, 09:39 AM
  4. Testing ground fault reduced voltage and blocking capability
    Last Post: January 29, 2016, 02:46 PM
