GE SR745 Protective Relay
  1. ElectricalTestTech's Avatar
    Affiliate Member
    Pro Subscriber
    Washington, DC
    69
    I was wondering if anyone had any type of spreadsheet or formula on how to calculate the currents needed to operate different parts of a differential slope. I am looking to be able to type in a primary winding current, and have it calculate the amount of secondary current needed to trip on differential. I have contacted GE and they do not have anything and basically state that we should just trust the relay. I have had so many relays fail in the past year that I do not trust their relays.
    .2*CT diff p/u
    25% slope1
    1*CT break
    98% slope 2
    16MVA, 1200:5 primary, 3000:5 secondary, 13.8kV-4.16kV, Dyn1
    I have a spreadsheet that allows me to input Winding 1 test amps and Winding 2 test amps. Based off of those it will tell me if I will see a trip or no trip. But I want to know the specific calculated pick up instead of having to continuously change my current values in the spreadsheet to get an approximate pick up.
    Thanks
  3. Relay1's Avatar
    Relay1 is offline
    Nov 2017
    Central Texas
    17
    Diff Spreadsheets
    .2*CT diff p/u
    25% slope1
    1*CT break
    98% slope 2
    Thanks
    I sent a couple of spreadsheets to your e-mail address. Hope they help!
  5. ElectricalTestTech's Avatar
    Affiliate Member
    Pro Subscriber
    Washington, DC
    69
    Quote Originally Posted by Relay1 View Post
    Thank you. I will check them out tomorrow. I am trying to figure out this algorithm. It makes me mad that GE canít provide a tool that other manufacturers do. Iíll be back at it tomorrow morning
    Thanks again
    Mar 2015
    Would you mind sharing them with me as well. I've ran into this same issue.
  9. Relay1's Avatar
    Relay1 is offline
    Nov 2017
    Central Texas
    17
    387 Spread Sheet
    Quote Originally Posted by Reef Donkey View Post
    Hello Reef Donkey,
    Hopefully there is a SEL-387 spread sheet attached here that may help you.
    Relay1
    Attached Files Attached Files
  1. CL protective device cycles?
    By Havik21 in forum NETA Level 4 Exam
    Last Post: November 2, 2018, 12:36 PM
  2. Silent sentinel protective relay book by Westinghouse
    By Larry5443 in forum P&C / Relay Testing Talk
    Last Post: December 21, 2015, 12:13 PM
