Results 1 to 3 of 3
Fluke 1750 Power Quality Meter Hard Reset (Procedure)
  1. SecondGen's Avatar
    357
    Sometimes in the field it may be necessary to hard reset the Fluke 1750 PQM when communications cannot be established by your PC or other device. Using the procedure will factory reset the device and wipe all memory/settings, allowing you to re-establish communications.
    Warning: This procedure involves breaking factory seals and should only be used in emergency situations when the meter cannot be sent to the factory for service as it will most likely void your warranty. Any data stored in the unit prior to performing this procedure will be erased, contact an authorized service provider if data needs to be recovered!!!
    Before resorting to a hard reset, try to unplug the unit and allow the UPS to fully drain before plugging it back and try again. Try to communicate with both a PC via Ethernet, and a PDA via Bluetooth (if possible). Sometimes communications can be re-established after performing this “soft-reset”.
    If all else fails, you can try this:
    Factory Reset Procedure for Fluke 1750 Power Quality Analyzer
    Step 1: Pull off yellow rubber footing on the bottom of the unit.
    Step 2: Remove the (6) screws holding the bottom housing plate on.
    Step 3: Remove the button battery cell from the circuit board.
    Step 4: Press and hold the small reset button for 5 seconds, located next to the button battery housing.
    Step 5: Replace the battery and bottom housing plate along with the yellow rubber footing.
    Step 6: Plug in the unit and try to connect with a PC via Ethernet.
    The Fluke 1750 PQM should now be fully reset and communicating. Date and Time setting will need to be changed, any data previously stored in the unit will be lost.
    Sep 2019
    FLUKE 1750, PROBLEMS WITH ETHERNET CONNECTION
    Hi SecondGen,
    Thanks for your input, I have 3 queries of the 1750 fluke
    1.- Is the ethernet cable direct or crossed? mine got lost
    2.- Can you download the Software from the fluke page? , or it needs some license to work.
    3.- no I have the PDA, can it be used or work only with the ethernet cable?
    Beforehand thank you very much
  5. SecondGen's Avatar
    357
    Quote Originally Posted by Davidfiee64 View Post
    Hi SecondGen,
    1. I believe it is a standard cross-over cable but honestly I've never had a reason to check. I usually try to keep both types on me for cases when I'm unsure or having problems connecting to something.
    2. You can download 1750 software here: https://www.fluke.com/en-us/support/...e-and-firmware
    3. Yes. The default method I use to connect is over ethernet using a Windows based PC running the latest version of Power Analyze from the Fluke website. I've had problems with the PDA in the past so I rarely bother with it anymore, I think there may be an Android app but I don't remember for sure.
  1. Fluke 1750 PQM data loss after utility switching operations
    Last Post: September 5, 2018, 07:39 PM
  2. Have you ever used a Fluke 1750 power analyzer?
    By NWILLJR1020 in forum Electrical Testing Talk
    Last Post: November 21, 2017, 06:09 AM
  3. Different types of Hard Hats
    By moshi666 in forum NETA Level 2 Exam
    Last Post: January 26, 2017, 10:05 PM
  4. EATON PX2000 Meter: How to Change IP Address in Power Xpert
    Last Post: September 29, 2016, 05:07 PM
  5. Replies: 1
    Last Post: March 2, 2016, 04:59 PM
