CL protective device cycles?
    Dec 2016
    A current limiting protective device will cut off the maximum peak fault current for currents within its current limiting range is less than which of the following?
    I was sure this was 3 cycles....
    This might be too high maybe 0.5?
    Jul 2018
    Quote Originally Posted by Havik21 View Post
    i always thought instantaneous was no intentional delay, i would choose lowest option.
    14
    Per Chapter 1. page 3 of Protective Relaying Theory and Applications by Walter A Elmore:
    Applied to a relay, high speed indicates that the operating time usually does not exceed 50ms (Three cycles on 60-Hz base). The term instantaneous indicates that no delay is purposely introduced in the operation. In practice, high speed and instantaneous are frequently used interchangeably.
    Remembered this line and thought it may be applicable.
  7. Wanderer20001us's Avatar
    Wanderer20001us is offline NETA Level III Pro Subscriber
    Michigan
    29
    https://iaeimagazine.org/magazine/20...nt-limitation/
    Good article to explain CL fuse behavior...
  9. rofo42 is offline Junior Member
    14
    Quote Originally Posted by Wanderer20001us View Post
    That is a phenomenal article. He has many other great articles as well. Thank you for posting.
    I've since came across a great piece in the Paul Gill book dealing with current limiting fuses.
    Chapter 8, page 439
    "Current limiting fuses melt and extinguish the arc in a half cycle or less. Non current limiting may melt in less than a half-cycle when subjected to very high values of short circuit current, but is unable to extinguish the arc in a half-cycle. Since the arc is a flexible conductor, the non current limiting fuse will allow short circuit current to reach its maximum peak value. The current limiting type of fuses are constructed with mechanisms to extinguish the arc, thereby preventing the short circuit current from reaching its maximum peak value."
    This picture, taken from Thomas A. Domitrovich's article, does a great job in explaining the paragraph from the Paul Gill book.
  1. Test your ANSI device number knowledge with our all new quiz!
    Last Post: July 1, 2014, 06:00 AM
