Practice Test Question: Negative Sequence
    Mar 2017
    19
    The question reads:
    "What can you do to create a negative sequence when testing a 47 relay?"
    The choices were apply 3x pick-up on a single phase, apply 1.732x pick-up on two phases, or reverse the rotation. All three of these would produce negative sequence voltage, but if you want to test a reverse rotation element (what 47's are typically used for), then the easiest thing to do is to just reverse the rotation. But technically all three of these can be used to create a negative sequence when testing a 47 relay. Why is only one of them correct?
  3. EEBSMSPE96 is offline Junior Member Pro Subscriber
    46 versus 47
    Quote Originally Posted by EricGoetz92 View Post
    The question reads:
    Answer:
    Many times negative phase sequence (A-C-B Rotation) is confused with negative sequence (current (I2) and voltage (V2)) quantities. Since the question refers to the testing of a 47 relay (which responds to negative phase sequence aka negative phase rotation i.e. A-C-B rotation), the correct answer to this question is "reverse the rotation" of your test source. Positive phase sequence is A-B-C Phase rotation which is what "normal" voltages and currents are on the grid. Hope this helps.
    Jun 2018
    Looks like you answered your own question my friend.
    Mar 2017
    19
    Quote Originally Posted by EEBSMSPE96 View Post
    Answer:
    That does make since. I was to hung up on symmetrical components and over thought it (which they were clearly anticipating since they made the other two answers viable options to make negative sequence voltage).
  1. XFMR test question - wye-delta TTR
    By dbryce89 in forum NETA Level 2 Exam
    Last Post: 1 Day Ago, 11:02 PM
  2. Practice Test Question: Interfacial Tension
    By EricGoetz92 in forum NETA Level 3 Exam
    Last Post: 2 Weeks Ago, 11:33 AM
  3. When would you most likely use a negative sequence relay?
    By Tseppish in forum NETA Level 3 Exam
    Last Post: October 9, 2018, 04:41 AM
  4. Practice Test Question: Which relay is used to protect feeders?
    By EricGoetz92 in forum NETA Level 2 Exam
    Last Post: June 11, 2018, 02:49 PM
  5. Insulation resistance test set question
