Practice Test Question: Interfacial Tension
    Mar 2017
    19
    So a practice question reads:
    "What would a decreasing value of interfacial tension indicate?"
    My answer was contaminants and in the the Paul Gill book it states that "It has been established that an IFT of less than 15 dyn/cm almost invariably shows sludging."
    So are "contaminants" and "sludging" different, is the Gill book wrong, or is the test question incorrect/written poorly? What is the correct answer?
    Jun 2018
    Quote Originally Posted by EricGoetz92 View Post
    What were the other answer options presented?
    Mar 2017
    19
    Quote Originally Posted by storm89 View Post
    I wish I had taken a screenshot of them, but I didn't. I think water/moisture might have also been an option. At the time, it seemed pretty cut and dry that it would be contaminants so I didn't screenshot it. What else do you think it could be? I am mainly a P&C guy, so oil samples aren't my strong suit, but even now when I look up more stuff about it, the main focus seems to be sludge build up (I'm pretty sure "sludge" wasn't explicitly an option). Are sludge and contaminants different? If deterioration was an option, would that be a better choice?
    Jun 2018
    I think sludging and contamination refers to separate issues. Without knowing the other choices it's hard to say what the best answer is but I found this link which says "changes in an oilís surface tension to be the earliest sign of contamination, sludge potential and oxidation."
    https://www.machinerylubrication.com...e-tension-test
    Contamination, sludging, and oxidation could all be correct I think.
    9
    Thank you, that article was very helpful
  1. XFMR test question - wye-delta TTR
    By dbryce89 in forum NETA Level 2 Exam
    Last Post: 4 Weeks Ago, 07:22 PM
  2. Practice Test Question: Which relay is used to protect feeders?
    By EricGoetz92 in forum NETA Level 2 Exam
    Last Post: June 11, 2018, 02:49 PM
  3. Insulation resistance test set question
  4. NETA II test question (cable area)
    Last Post: February 15, 2018, 10:52 AM
  5. Test Question--High Current Injection
    By alexlounsbury in forum NETA Level 3 Exam
    Last Post: July 10, 2017, 11:38 AM
