Results 1 to 1 of 1
1 phase AC 115V 1 HP motor full load current calc.
  1. davidb is offline Junior Member Pro Subscriber
    Mar 2018
    The full load current for a single phase alternating current 115 volt, 1 horsepower motor is?
    My answer was 8 Amps based on formula when Horsepower & Voltage are known factors.
    Horsepower X 746
    Amps = _________________________
    Volts X Efficiency X Power Factor
    Correct answer indicates 16 Amps based on NEC Table 430.248.
    Do we need to remember numerous Tables or need to know how to calculate such questions?
    Thank-you
  1. Safely discharge HV feeder using load break disconnect switch (procedure)
    Last Post: August 17, 2020, 01:08 PM
  2. Testing liquid filled transformers with load break bushings
    By GDerr81 in forum Electrical Testing Talk
    Last Post: November 15, 2016, 02:47 AM
  3. A phase-to-ground fault would primarily produce which type of current?
