IAC overcurrent relay, target and seal in coil
    Jun 2016
    28
    On a typical IAC overcurrent relay, the target and seal in coil is in series with which of the following?
    Instantaneous unit
    None of the other answers are correct
    Time Unit
    Current transformer
    Instantaneous unit & Current transformer & Time Unit
  3. Ore905 is offline Junior Member
    Quote Originally Posted by jflan13 View Post
    Instantaneous unit
    Time Unit
    Current transformer
    To be honest I'm not a fan of most of the questions in the quizzes on this site but most times seal in coil is in series with time element trip contact on the old electromechanical units.
    Jun 2016
    28
    Quote Originally Posted by Ore905 View Post
    Thank you for the help again
    307
    Instantaneous unit
    Time Unit
    Current transformer
    The seal-in unit has its coil in series and its contacts in parallel with the contacts of the time-overcurrent unit, such that when the induction unit contacts close, the seal-in unit picks up and seals in. When the seal-in unit picks up, it raises a target into view, which latches up and remains exposed until released by pressing a button.
    https://www.eiseverywhere.com/file_u...a3_GEIAC77.pdf
    Jun 2016
    28
    The seal—in unit has its coil in series and its contacts in parallel with the contacts of the time—overcurrent unit, such that when the induction—unit contacts close, the seal—in unit picks up and seals in. When the seal—in unit picks up, it raises a target into view, which latches up and remains exposed until released by pressing a button.
    Awesome, thank you
  1. When would you most likely use a negative sequence relay?
    By Tseppish in forum NETA Level 3 Exam
    Last Post: October 9, 2018, 04:41 AM
  2. Time Overcurrent Relay 51
    By jflan13 in forum NETA Level 3 Exam
    Last Post: June 7, 2018, 07:15 AM
  3. Looking for help, CO-2 relay
    Last Post: June 6, 2018, 10:04 AM
  4. Proper connection for overcurrent relay with parallel CT's
    Last Post: October 21, 2017, 08:07 AM
