Results 1 to 3 of 3
Dry Tranformer Turns Ratio
    Nov 2017
    How much deviation is allowed from the calculated value ( three phase dry transformer Rated voltage 11000 / 415 volts, Rated Power 2000KVA)? Kindly also mention the reference of Standard.
    343
    TTR standard deviation
    The standard deviation as defined by ANSI/IEEE C57.12.00-2006, Section 9.1 states that results should be within 0.5% of nameplate markings, with rated voltage applied to one winding. The TTR with accuracy of 0.1% is accepted as a referee.
    - Power Equipment Maintenance and Testing, Paul Gill
    ANSI/NETA standards also state that TTR results should be within 0.5%
    Jun 2016
    28
    TTR
    Quote Originally Posted by shamimkhan View Post
    In the NETA-MTS and ATS under electrical test results it says, "Turns-ratio test results should not deviate more than one-half percent from either the adjacent coils or the calculated ratio." Page 32 for both books.
  1. Saturation test of a 1500/5 multi-ratio CT
    By Tseppish in forum Electrical Testing Talk
    Last Post: February 26, 2019, 10:47 PM
  2. What is the turns ratio?
    By franko26 in forum NETA Level 2 Exam
    Last Post: July 10, 2018, 03:41 PM
