Results 1 to 10 of 11
Questions from recent Level 2 exam (10/2017)
    Nov 2017
    Here are some recent questions from the Level 2, they were given to me by a co-worker who took the exam in October.
    1. What connections are on a DLRO meter?
    A) 2 current outputs, 2 voltage outputs
    B) 2 current measurements, 2 voltage measurements
    C) 2 current measurements, 2 voltage outputs
    D) 2 current outputs, 2 voltage measurements
    2. One worker is standing 3ft away from an exposed live part and another is standing 6ft away. How much incident energy is the 6ft worker exposed to in comparison to the 3 ft worker?
    A) 1/2
    B) 1/16
    C) 1/4
    D) ????
    3. Given a 3-phase circuit with 250kvar and 480v, what is the current?
    4. Under normal operating conditions, in what state is a battery charger set to?
    A) Charging
    B) Float
    C) Equalizing
    D) ????
    5. Which instrument is used to locate a 15kV underground cable fault?
    A) DLRO
    B) Time/Motion Analizer
    C) Time domain reflectometer
    D) Insulation resistance tester
    6. Your pickup results are high on an electromechanical relay, what is likely the cause?
    A) Contacts are dirty
    B) Loose connections on case
    C) Spiral spring adjustment
    D) ???
    7. What grade bolt is this (given picture of a bolt head)
    A) Grade 1-2
    B) Grade 3
    C) Grade 5
    D) Grade 8
    Stuff to know:
    Protective ground sizes and functionality
    LOTO process
    Confined space
    Power triangle and power factor calculations
    Fuses
    Grounding principles
    Use of meters and the leads associated
    Contact resistance and how it works
    One lines and symbols
    Relays and symbols associated
  3. Rdhorn is offline Junior Member
    Dec 2016
    Here are some of the answers, please feel free to add or contradict my answers
    Quote Originally Posted by Tech1120 View Post
    D)
    A) 1/2
    B) 1/16
    C) 1/4
    D) ????
    I don't know. I would have to say 1/2 or 1/4 but it would be a guess
    I don't know if I can answer that with just this information. I would be curious to hear someone else answer
    A) Charging
    B) Float
    C) Equalizing
    D) ????
    B) Float
    A) DLRO
    C) Time domain relectometer
    D) ???
    I don't know
    A) Grade 1-2
    B) Grade 3
    C) Grade 5
    D) Grade 8
    No dashes is 2, add plus for the other grades
    Stuff to know:
    LOTO process
    Confined space
    Fuses
  5. dvaldez is offline Junior Member Pro Subscriber
    Quote Originally Posted by Rdhorn View Post
    Anybody else have anymore questions from the exam?
  7. NoWorldOrder is offline Junior Member Pro Subscriber
    Feb 2017
    D) ???
    Tightening spiral spring increases pickup, loosening the spring will decrease pickup
    Nov 2017
    What is this reading
    A phase
    B phase
    A and C
    B and C
    Nov 2017
    I did some research and found the equation I = kVAR / (V*1.732) but I don't have the answer choices to check my answer 0.30 A
  13. NoWorldOrder is offline Junior Member Pro Subscriber
    Feb 2017
    A phase
    B phase
    A and C
    B and C
    A phase
    Michigan
    40
    250,000/(480*1.732)=~300A
    Michigan
    40
    A phase
    B phase
    A and C
    B and C
    It's reading a, because the DLRO should push the rated amps through Phase C, and with no amp on the P2 lead through phase B resistance, the reading across Phase A would be unaffected.
  19. SecondGen's Avatar
    411
    A phase
    B phase
    A and C
    B and C
    A phase. If anyone is having trouble with this one, just look at the test leads carefully and you will notice that B and C bus are simply used as extensions of the test leads.
  1. NETA 4 Exam Questions 1/2017
    By ddd675 in forum NETA Level 4 Exam
    Last Post: March 1, 2020, 04:16 PM
  2. Replies: 3
    Last Post: January 7, 2018, 01:23 AM
  3. Tech Quiz Updates for 2017
    Last Post: September 5, 2017, 06:24 PM
  4. Neta 3 Exam pointers and questions
    By Zepold72 in forum NETA Level 3 Exam
    Last Post: April 29, 2016, 05:25 PM
  5. Official NETA Level 2 Exam Most Missed Questions, Spring 2000
    By SecondGen in forum NETA Level 2 Exam
    Last Post: March 16, 2016, 08:18 PM
