Results 1 to 10 of 10
What's wrong with this picture?
Go to latest post
  1. SecondGen's Avatar
    243
    Hint: "I need you to take an oil sample."
    Washington, DC
    43
    If I rotate the picture 180 degrees, I could take a sample. 😂
    Needs a sample valve in the bottom plug. Not a pipe plug.
    14
    Whoops!
    Apr 2014
    I came across the same thing on some transformers that were built for a local utility out here in California.
  11. ksviveksiddarth is offline
    Be Different and Make the Difference
    May 2017
    India
    You have to open the highlighted (yellow) bolted dummy cover for the drain valve
    Washington, DC
    43
    Quote Originally Posted by ksviveksiddarth View Post
    Are you trying to get an air sample or an oil sample ksvivik?
  15. ksviveksiddarth is offline
    May 2017
    India
    I thought your trafo could be a one similar to this ...
    vivek..
    Jun 2018
    Yup! Total crap! Pull a vacuum and put a valve in that bottom plug!
    19
    But they put the valve in facing down so no problem then
