Utility vs. Customer Phase Rotation - Level III Test Question (Recent 7/16)
    Jul 2016
    Thoughts on this?
    A utility defines their horizontal bus at the customer point as ABC left to right facing the customer with ABC rotation. The customer defines their buses as ABC left to right facing the utility but with CBA rotation. For a first time connection the customer has to:
    A: Swap A & B phases and leave phase sequence alone
    B: Swap B & C phases and leave phase sequence alone
    C: Leave phasing alone and change phase sequence to ABC
    D: leave phasing and phase sequence alone.
    I guessed D because and don't know if I'm right. Is there a proper procedure here? Explain if possible.
    May 2016
    I would also choose D. Utility is Rotating A-B-C left to right, so if customer is wired C-B-A then the rotation would naturally be C-B-A left to right. What gets confusing is which side of the line you are looking at. They try to trick you by saying "facing the utility" or "facing the customer". It's easier if you draw it out and flip it around.
    A-B-C (Utility)
    C-B-A (Customer)
    Jan 2017
    I took the exam last Friday 1-27-17 and answered this question with D also.
    Feb 2016
    Quote Originally Posted by BRAD2121 View Post
    Thoughts on this?
    D is the correct answer. If you read through A,B, and C choices they are all having the same effect on the sequence/phasing. Basically they are all the same answer with different means of getting there.
    Aug 2021
    Heres another way to look at it visually as well that helps see the rotation swap. Click image for larger version.
  1. Saturation test of a 1500/5 multi-ratio CT
    By Tseppish in forum Electrical Testing Talk
    Last Post: August 4, 2021, 10:21 AM
  2. Replies: 9
    Last Post: August 16, 2018, 02:28 PM
  3. Insulation resistance test set question
    Last Post: June 10, 2018, 12:52 PM
  4. Replies: 2
    Last Post: February 2, 2016, 01:35 PM
