Page 2 of 2 FirstFirst 12
Results 11 to 16 of 16
Understanding power factor is easy when you relate it to beer!
    #11
    Dec 2018
    Atlanta, GA
    27
    Quote Originally Posted by veracon0700 View Post
    Here is a classic analogy using beer that will help you to better understand power factor...
    Imagine you have a freshly poured mug of your favorite brew sitting in front of you.
    Attachment 75
    The drinkable portion of your beer is represented by Real Power (expressed in kW). Real Power may also be called Actual Power, Active Power or Working Power. This is what actually powers electrical equipment and performs useful work (in this case, quenching your thirst).
    Along with your brew comes a little bit of foam, and that foam just isn't going to do anything useful, so consider this undrinkable portion of your beer to be Reactive Power, represented by KVAR. This is the power that magnetic equipment like transformers, motors and relays need to produce their magnetizing flux. Think of the foam as a reaction from pouring the beer.
    The combination of drinkable beer (kW) and foam (kVAR) inside of your mug represents the Apparent Power, or KVA.
    Power Factor is simply the ratio of Real Power (kW) to Apparent Power (kVA) and is represented by the following formula: PF = KW / KVA.
    Using our beer analogy you could write the formula like this: PF = Beer / Drinkable Beer + Foam.
    For any given KVA,the more foam you have (the higher the percentage of KVAR), the lower your ratio of KW (beer) to KVA (drinkable beer + foam). Thus, the lower your power factor.
    The less foam you have (the lower the percentage of KVAR), the higher the ratio of KW (drinkable beer) to KVA (drinkable beer plus foam). As your foam (or KVAR) approaches zero, the power factor approaches 1.
    Incase anyone wants to see the Power Triangle
  2. #12
    Jun 2019
    This is a lot better than the power triangle they teach in school. This is a very straightforward example. I'm going to remember and use this.
  4. #13
  5. Raj5454 is offline Junior Member
    May 2021
    Attachment 75
  6. #14
  7. Raj5454 is offline Junior Member
    May 2021
    Power Factor
    Power Factor = kVA/kW = (kW + kVAR)/kW
    Lesser the kVar, the better the power factor
    But we can not reduce the kVAr of the electrical machine.
  8. #15
  9. Kalbi_Rob's Avatar
    290
    Quote Originally Posted by Raj5454 View Post
    Yes you can. First is through engineering and redesigning of the machine with power factor correction built in, but this is costly and has to be built into the machine before use. Secondly, if you work in substations, you know we can power factor correct with the use of capacitor banks and reactors.
    KVAR is only produced through reactive (imaginary) components such as capacitance and inductance. Since capacitance is inversely proportional to inductance, we can use the opposite component to counteract the other.
  10. #16
    Jul 2020
    Washington, United State
    44
    Quote Originally Posted by Scubasteve523 View Post
    Very helpful!!!
    hahahaha
  1. Power Factor for New Mineral Oil
    Last Post: February 22, 2020, 05:12 PM
  2. Replies: 9
    Last Post: August 16, 2018, 02:28 PM
  3. Replies: 7
    Last Post: May 28, 2018, 04:21 PM
  4. Easy way to calculate transformer fault current
    Last Post: June 11, 2015, 06:40 PM
