Page 2 of 2 FirstFirst 12
Results 11 to 16 of 16
What methods do you use for corona suppression when testing cable?
    #11
    Mar 2018
    8
    Great tip, I will be trying this next time I test cable.
    When wrapping the ball, you may want to adjusts the length of the foil to wrap around the cable center a little bit and secure it with a rubber band. This way you are sure the foil is in contact with the center conductor.
  2. #12
    307
    Quote Originally Posted by whiskers View Post
    Thanks, I was wondering about the best way to make uniform contact. The rubber band idea is good, I'm thinking it would also be good to jam the foam on the cable first and then wrap so you can stuff the foil way down in the hole.
    Another thought would be to make some up with various size holes or just put extra wraps on the cable until it fits. Next cable job will double as arts and crafts day.
  4. #13
    Dec 2018
    What works for me are corona balls. Not the expensive ones. Just go to a craft store and buy a bunch of those Styrofoam balls of different sizes and bring along a roll of aluminum foil.
    Wrap the ball in the foil and just jam it on the end of the cable. Works every time.
    Where do you place lead once you add the styrofoam balls
  6. #14
    Mar 2018
    8
    Corona Mitigation Testing Cables
    Quote Originally Posted by TrapFlyVenus View Post
    Prior to adding the Styrofoam balls, I use a small piece of hipot wire and twist it tight on the inner conductor right at the beginning of the rubber insulation, then place the ball on to the wire.
    Hope that helps.
    Bill
  8. #15
    Dec 2018
    Atlanta, GA
    26
    Quote Originally Posted by madMAX View Post
    Corona Balls? Sounds like you got that fancy stuff, Alex. My company only provides the bare essentials. Using rubber boots and blankets seems like a good idea except large blankets can be a pain to work with. Maybe I can rob some boots if I come across some on a job. The insulating plastic I have is only good for 8kV I think.
    We do the same thing.
  10. #16
  11. gbriske is offline Junior Member Pro Subscriber
    Sep 2018
    Wow I've never thought of this, a couple of our sets don't have the corona balls but I will be adding some of these for future cable tests thanks for the tip!
  1. Replies: 2
    Last Post: July 5, 2018, 04:35 PM
