Results 1 to 2 of 2
Help with questions from practice exams
    Jun 2015
    9
    Electrical/Physical Theory
    Voltage in an electrical system:
    Your Answer: Is a measurement of power flow
    General Test Equipment
    Which of the following would you expect to find on a test set used to measure insulation-resistance?
    Your Answer: Line, Ground, Return
    Circuit Breakers and Circuit Switchers
    If secondary current is used to test a circuit breaker solid-state trip device, the technician should realize that this test does not check ____________.
    Your Answer: the output signal from the trip device to the trip coil (flux shift device)
    Electrical Protective Devices
    On which of the following would an Instantaneous Overcurrent Relay be most effective in protecting?
    Your Answer: Bus
    i think your looking for answers
    Quote Originally Posted by justin6354 View Post
    Your Answer: Bus
    i think you git these wrong and are looking for the correct answers
    voltage in an electrical system - same as the water pressure out of a hose
    Which of the following would you expect to find on a test set used to measure insulation-resistance? positive negative and guard
    If secondary current is used to test a circuit breaker solid-state trip device, the technician should realize that this test does not check ____________. your are not checking the cts
    On which of the following would an Instantaneous Overcurrent Relay be most effective in protecting? feeder
    hope that helps feel free to email me if any other questions
  1. New practice questions and circuit breaker quiz now available
    Last Post: June 17, 2015, 03:05 PM
  2. Replies: 0
    Last Post: December 1, 2014, 06:00 AM
