Results 1 to 10 of 11
What is the reactive power?
    • A given 120VAC 60Hz circuit has a load of 10A with a 20° lagging power factor for 30 minutes. What is the reactive power?
    Someone help with this one?
  3. cecil6108@yahoo.com is offline Junior Member Pro Subscriber
    May 2015
    You have to use the trigonometry principles. Remember SOH,CAH,TOA. You will need to calculate for the apparent power which is volts times amps and they give you the angle for theta. VA=1200. So the solution would be cos. 20 times 1200.
    Oct 2015
    10
    Quote Originally Posted by cecil6108@yahoo.com View Post
    I'm afraid you've got your trig functions mixed up. Reactive power will be sine(theta), where (theta) is the power factor angle. Be careful to first compute the apparent power (V*I) as was done here, then multiply by sine(theta).
    cos(theta) would compute the power factor, which would yield active (real) power when multiplied by the apparent power.
    In this case, the reactive power would be 410.4 VAR. If the question were to ask anything about inductive or capacitive, the fact that the load angle is lagging tells you that the reactive power is inductive.
  7. ghernandez is offline Junior Member Pro Subscriber
    Feb 2015
    Trigonometry Help for Level 3 Exam
    Studying for this level 3 exam..... having some set backs with the trigonometry part of it... any suggestions...
    Sep 2015
    When I was doing my degree, these two sites had saved me a thousand times when trying to get through complex math. Try:
    https://www.mathsisfun.com/algebra/trigonometry.html
    https://www.khanacademy.org/math/tri...ight-triangles
    Hope this helps, and good luck!
  11. MDTannen is offline Junior Member
    Quote Originally Posted by McDaniel8402 View Post
    im getting 0.9129..... for sine 20. The product of that and 1200 is 1095.5. Am I missing something? It's late and I'm a little burnt out.
  13. SecondGen's Avatar
    Quote Originally Posted by MDTannen View Post
    How did you get 0.9129? This is how i punch it in my calc:
    SIN(20) = 0.342
    1200 * SIN(20) = 410.42
  15. JoshQ86 is offline Junior Member Pro Subscriber
    Southern California
    SIN(20) = 0.342
    Calculator is not set in degrees.
  17. SecondGen's Avatar
    Quote Originally Posted by JoshQ86 View Post
    Ah, yes. SIN(20) in radians will give you 0.9129
    Jan 2017
    26
    Quote Originally Posted by trhea@saberpower.com View Post
    to help remember what the powre triangle is, i use the word ART ( APPARENT, RACTIVE AND TRUE) just remember how the triangle looks and ur good to go
