Results 1 to 8 of 8
Help with calculating percent error
    If a current of 30 amps is measured with a 100 amp 3% ammeter, the maximum possible error in terms of actual error is:
    Im having problems calculating these types of questions, could someone help?
  3. Kimbo Slice is offline Member Pro Subscriber
    Mar 2015
    35
    Milwaukee, WI
    Percent Error reply
    For percent error on that device:
    100Amps X 3% = plus or minus 3 from 100 or a range of 97A to 103A when measuring 100A.
    If the error is +/- 3 amps then your 30Amps may be 27A to 33A.
    if the device is listed as a 3% tolerance over all measurement ranges then use 30A X 3% = plus or minus 0.9A or range of 29.1A to 30.9A
    12
    Quote Originally Posted by stuebes View Post
    The correct way is this. 30/3=10
    Minnesota
    Percentage error calculation
    What am I missing if I keep coming up with 3.9%?
    If 4000 was the specified value, and 3850 was the measured value, what is the percent error?
  11. patelnipul5 is offline Junior Member Pro Subscriber
    Nov 2015
    3062 Renard Lane, Saint Charles, Illinois
    Percentage error
    Please see below for percentage error calculation.
    Step 1: Calculate the error (Subtract one value from the other)
    Step 2: Divide the error by the specified value (we get a decimal number)
    Step 3: Convert that to a percentage (by multiplying by 100 and adding a % sign)
    % error =((Specified value-Measured value)/ Specified value )X 100 %
    = ((4000-3850)/ 4000) X 100 %
    = 0.0375 X 100 %
    = 3.75%
    Jan 2017
    26
    Quote Originally Posted by Flashman View Post
    I always do
    [expected (specified) - Calculated (Measured)] / expected (specified)
    this will give you a decimal, which can be converted into a percentage by multiplying by 100
  15. simmonmw71 is offline Junior Member Pro Subscriber
    Oct 2017
    Comanche, TX
    Quote Originally Posted by Mmfz85 View Post
    The correct way is;
    2% of 100 is 2.
    2 is the maximum error.
    2/30 is 0.0667 which is 6.6%
  1. What is the reactive power?
    Last Post: October 5, 2017, 03:33 PM
