coefficient of coupling
A certain transformer has a turns ratio of 1 and a 0.85 coefficient of coupling. When 2 V ac is applied to the primary, the secondary voltage is
A. 1.7 V
B. 0.85 V
C. 1 V
D. 0 V
secondary voltage?
The primary coil of a transformer is connected to a 60 V ac source. The secondary coil is connected to a 330 load. The turns ratio is 3:1. What is the secondary voltage?
A. 2 V
B. 20 V
C. 180 V
D. 18 V
primary winding
The primary winding of a power transformer should always be
A. open
B. shorted
C. switched
D. fused
reflective load
When a 200 load resistor is connected across the secondary winding of a transformer with a turns ratio of 4, the source "sees" a reflective load of
A. 50
B. 12.5
C. 800
D. 0
secondary voltage
When a 6 V battery is connected across the primary of a transformer with a turns ratio of 8, the secondary voltage is
A. 0 V
B. 6 V
C. 48 V
D. 0.75 V
total flux generated
What is the coefficient of coupling for a transformer in which 4% of the total flux generated in the primary does not pass through the secondary?
A. 0.4
B. 4
C. 9.6
D. 0.96
load resistance
A transformer has a 1:6 turns ratio and a secondary coil load resistance of 470 . The load resistance as seen by the source is
A. 1.3
B. 7.8
C. 78
D. 13
induced voltage
When the speed at which a conductor is moved through a magnetic field is increased, the induced voltage
A. increases
B. decreases
C. remains constant
D. reaches zero
flux density
For a given wirewound core, an increase in current through the coil
A. reverses the flux lines
B. decreases the flux density
C. increases the flux density
D. causes no change in flux density
Vysakh9292
What kVA rating is required for a transformer that must handle a maximum load current of 8 A with a secondary voltage of 2 kV?
A. 4 kVA
B. 0.25 kVA
C. 16 kVA
D. 8 kVA
8A multiplied by 2kV = 16kVA.
Last Post: July 17, 2019, 04:16 PM
By Beaumont1188 in forum NETA Level 3 Exam
Last Post: June 28, 2018, 10:32 PM
