Page 8 of 16 FirstFirst ... 678910 ... LastLast
Results 71 to 80 of 159
Article: Tech Quiz
    #71
  1. dhartmanpsfc's Avatar
    dhartmanpsfc is offline Junior Member Pro Subscriber
    10
    Pages 4 and 5 of the OSHA document indicate that the addition of forced air ventilation can eliminate the need for a permit.
  2. #72
  3. dhartmanpsfc's Avatar
    10
    Per NETA ATS 2017 All of the answers listed are required, none are optional
  4. #73
  5. dhartmanpsfc's Avatar
    10
    When maintenance testing microprocessor relays, which of the following tests is optional according to NETA/ANSI standards?
    Insulation resistance of each circuit to ground
    Functional operation of each element
    Apply voltage or current to analog inputs
    Control verification
  6. #74
  7. BIGLARS702 is offline Junior Member Pro Subscriber
    Oct 2017
    Quote Originally Posted by dhartmanpsfc View Post
    believe the question was asking about maintenance testing. so maybe the MTS would have a different requirement.
  8. #75
  9. JPG4_CE is offline Junior Member
    Jul 2017
    Make sure to check calculator is in Degrees.
  10. #76
  11. Samuel is offline Junior Member
    Jan 2018
    Really
    Quote Originally Posted by achapp3 View Post
    Do not share information with other people until after the test period is over, they do not give the results of the test until 4-6 weeks which means they do not have a passing score set yet. If you help others it will reduce your own chances of passing.
    Kind of a dick way of looking at things.
  12. #77
    16
    Microprocessor relays
    Insulation resistance is optional
  14. #78
    Dec 2017
    32
    10. What mode of operation of a power factor set is used for a C1 test?
    Your Answer: UST
    isn't :
    C1 UST
    C2 GST
    HOT Collar test GST
    Overall test for bushings GST
  16. #79
    Dec 2017
    32
    Quote Originally Posted by Achandler View Post
    On MTS you only test the elements been used/programmed.
  18. #80
    Dec 2017
    32
    A coil has an inductance of 3 H and a wire resistance of 15 ohms. How long will it take for the current to reach its full value?
    45 s
    0.2 s T=(L/R) for time constant
    1.0 s T=(L/R) ... 5*T … for max value
    25 s
    Question is not asking for Time Constant.
  1. New practice questions and circuit breaker quiz now available
    Last Post: June 17, 2015, 03:05 PM
  2. Test your ANSI device number knowledge with our all new quiz!
    Last Post: July 1, 2014, 06:00 AM
