Test Question--High Current Injection
    Houston TX
    I disagree that my answer was wrong. The question:
    7. To test the long time delay function of a breaker which is set for 1000 amps ___________ test current is needed.
    From memory answers were:
    a. 1000A
    b. 1500A
    c. 3000A
    d. Need more information
    I chose D, because both B and C could be correct. I also wondered if it was a trick question with the wording. LTD is set in time, they don't specify that 1000 amps is the LT pickup. My answer was marked wrong. If LTD was always to be tested at 3x, then we wouldn't need TCC's, just a standard range. I've tested a 4000a breaker at 8000 to keep a test set from overheating. It would take a lot of time, but I could test the long time function of a 1000a pickup at 1500 amps.
    I dislike that in some questions, tricks are tricks, yet in others, the generic standard seems to be the right answer.
    Anyone else stumble on this?
    Reply to Post •
    Jan 2016
    It would be C
    You could test the pickup value at 1000, but the question ask for time delay which would be 3x the rated current which would be the answer C, 3000.
    Reply to Post •
    Houston TX
    Quote Originally Posted by Mcfly89 View Post
    You could test the time delay at 3x. You could also test it at 1.5x, 6x, 10x... We have TCC's to chart every level of current flow, 3x is just a standard that's been used for convenience. NETA doesn't require 3x, nor does any other governing body that I've seen.
    Just because a practice is common doesn't mean it's a rule.
    Reply to Post •
  7. Larry5443's Avatar
    Larry5443 is offline
    Cabinet Rat Neta Level 4
    17
    Quote Originally Posted by alexlounsbury View Post
    This was talked about at the Neta conference and it was agreed that there is no standard for this type of question.
    Reply to Post •
  1. Level III Test Question (Recent 7/16)
    By BRAD2121 in forum NETA Level 3 Exam
    Last Post: January 30, 2017, 01:55 PM
  2. How to Test Breaker through Current Injection Tester ?
    Last Post: January 24, 2017, 05:38 PM
  3. Insulation resistance test set question
    Last Post: July 20, 2016, 12:36 PM
  4. Looking for high current testing standard for breakers
    By Larry5443 in forum Electrical Testing Talk
    Last Post: July 21, 2015, 10:52 PM
  5. Replies: 4
    Last Post: January 24, 2015, 12:34 PM
