Results 1 to 3 of 3
Testing liquid filled transformers with load break bushings
  1. GDerr81 is offline Junior Member
    Jul 2015
    hey all
    just kinda curious what methods the community uses to connect test leads (doble,ttr,megger,WR) to the high side of a transformer with load break elbows.
    Ive always gotta use a loadbreak elbow probe which has nothing to attach the hook to. I attach an alligator clip to the end of the probe and connect to that. Im sure there's something better out there.
    Reply to Post •
  3. GavinK5 is offline Junior Member
    Aug 2015
    23
    If you can get your hands on some old elbows the best thing to do is cut the probes out of those. Bolt a lug on the end of them and you have yourself a set of test pins that will plug right into the transformer, then you can clip your leads to the lugs. A set of 4 should cover most applications.
    Name:  1444897584_Load Break Elbows.jpg
    Reply to Post •
  5. JP1946 is offline Junior Member
    Jan 2016
    We put all-thread couplings on the threaded end of an old test probe and put an eye bolt in the other side of the coupling. Makes it easier to pull out of the bushing.
    Reply to Post •
  1. Safely discharge HV feeder using load break disconnect switch (procedure)
    By SecondGen in forum Safety and Arc-Flash Talk
    Last Post: June 20, 2016, 05:07 PM
  2. Danger after lockout of GE Power Break equipped with electric charge
    Last Post: April 11, 2016, 02:38 PM
  3. Help with calibrating an oil-filled motor overload relay
    By trhea@saberpower.com in forum Electrical Testing Talk
    Last Post: June 30, 2015, 08:47 AM
