Results 1 to 9 of 9
Cable fault locating questions
    Nov 2014
    17
    The main objective of cable fault location is to _____________.
    a. Identify the cause of the fault
    b. Identify which circuit to de-energize
    c. Identify where to pull new cable
    d. Reduce the cost of down time of service
    Could use help with this question.
    Reply to Post •
    Nov 2014
    17
    In the thumper method of cable fault location, the fault is pinpointed at _________.
    a. the point of the earth movement
    b. the power cable termination
    c. the point where static waves are emitted
    d. where the high voltage surge arcs over and makes a loud noise
    Also need help with this question.
    Reply to Post •
    Thumper
    Quote Originally Posted by adamwilson View Post
    Capacitor Discharge Systems more commonly know as a Thumpers is used for underground cable faults. it generates a capacitive charge at the voltage that you select and then discharges it at a predetermined rate. once "Thumping" you will be able to hear the arc at the point of fault. Usually you need to use a listening device in order to hear it, although it is possible to hear the fault with out it if you are standing directly over the ground where the fault is and its not to deep.
    Becuase the Thumper in its self is a destructive method to locating cable It is strongly recommended that you first trace the cable using a cable tracer then use a TDR (Time domain reflectometer) to find the approximate location of the fault and then proceed with the thumper now having a general idea of where the fault is and reducing the damage to the cable and preventing damage to the nearby phases.
    So going back to the question i would answer with "D"
    Reply to Post •
    Nov 2014
    17
    Hey, thanks that was a very helpful explanation! What's your opinion about this one:
    I'm stuck between A and C but leaning toward "identify where to pull new cable." This seems to be the only reason why we ever use the thumper. What good comes from knowing the cause of the fault?
    Reply to Post •
    My answer would be c, the main objective of cable fault is to locate where the actual fault occured in order to repair the damaged cable. Where the fault occured does not tell us what was the cause of the fault, it just told us what point had the weakest insulation on that circuit. Hope that helps you.
    Reply to Post •
    Nov 2014
    17
    Very helpful. That's pretty much what I was thinking. Thanks again!
    Reply to Post •
    Nov 2016
    Thanks for your valuable reply sir
    But sir i still need a more detailed answer.
    Could you please tell me in little more detail?
    Reply to Post •
    Good info.
    Reply to Post •
    Nov 2016
    Reply to Post •
  1. Cable hi-pot withstanding time, why 15 minutes?
    By moon1958moon in forum Electrical Testing Talk
    Last Post: October 14, 2016, 08:58 AM
  2. Testing ground fault reduced voltage and blocking capability
    Last Post: January 29, 2016, 01:46 PM
  3. Cable hi-pot step voltage test
    By cjones09 in forum Electrical Testing Talk
    Last Post: August 25, 2015, 06:38 AM
  4. What is ground fault blocking capability?
    By madsenate in forum Electrical Testing Talk
    Last Post: June 23, 2015, 11:03 AM
  5. Cable Insulation Precentage
    By CanTest in forum Electrical Testing Talk
    Last Post: June 24, 2014, 04:21 PM
