Results 1 to 10 of 15
Neta 3 Exam questions
    Nov 2015
    9
    Does anybody have any pointers to take the Neta # 3 exam. I get anxious when I take tests. i failed it once and I want to pass it this time> i have been taking a lot of quizzes and I do okay(PASS) but somehow I dont feel to confident. I dont have a lot of experience with relays.
    Reply •
    OH/MI
    32
    took my 3 today, the formula sheet is slightly different if you've taken it in the past. the phase sequence formulas were not on the sheet.
    Id guess 60% or more questions were relay and metering. unfortunately I missed passing by 2 questions. Id also guess maybe 30% of the questions i've seen listed here.
    One questions that comes to mind was something like " a given circuit is 120 vac and has a draw of 10 amps phase is at 10 degrees with 45 magnitude what is the kvar? "i believe these were the choices"
    a. 750
    b. 1155
    c. 1200
    d. 77.5
    Not sure how to solve this you may see something similar.
    Reply •
    Mar 2015
    29
    took my 3 today, the formula sheet is slightly different if you've taken it in the past. the phase sequence formulas were not on the sheet. Id guess 60% or more questions were relay and metering. unfortunately I missed passing by 2 questions. Id also guess maybe 30% of the questions i've seen listed here. 1 that comes to mind was something like " a given circuit is 120 vac and has a draw of 10 amps phase is at 10 degrees with 45 magnitude what is the kvar?
    a. 750
    b. 1155
    c. 1200
    d. 77.5
    Was this your first time taking the Neta 3? If not did the questions change a lot? Sorry that you didn't pass.
    Reply •
    OH/MI
    32
    1st attempt at the 3. its been over a year since i took the 2. The format of the test is pretty similar i was expecting it to be way different reading some of the stuff here but it wasn't to bad. i just took another practice test for giggles and there are a lot of questions i seen on the 3 that i have yet to see here. if you have access to the neta quiz's that are published in the magazine there was quite a few of them on the test.
    Reply •
    Nov 2015
    9
    a. 750
    b. 1155
    c. 1200
    d. 77.5
    Q=V x I x SinΦ?
    Reply •
    Nov 2015
    9
    but still dont get any of those choices??
    Reply •
    Nov 2015
    9
    how do i inplement the magnitude in this?
    Reply •
    Apr 2014
    61
    a. 750
    b. 1155
    c. 1200
    d. 77.5
    Also not sure how to solve this, somehow need to find real power first. Where does the 45 magnitude come in?
    Can anyone help provide a solution?
    Reply •
    Sep 2015
    Possible Solution
    V = 45 mag, 10 degrees
    V phasor notation = 45*cosine(10degrees) - 45*sine(10degrees)*imaginary number
    V phasor notation = 44.3 - 7.8*imaginary number
    44.3 = real voltage
    7.8 = reactive voltage
    kvar = reactive voltage * amps
    kvar = 7.8*10amps
    kvar = 78
    78 is close to 77.5
    See if that works
    Reply •
    OH/MI
    32
    i have no idea, i tried figuring it out for about 20 minutes during the test and gave up. was hoping someone else here could shed some light. good luck tomorrow. a good portion of the questions i did see that were familiar to here were reworded ever so slightly it will trip you up.
    Reply •
  1. NETA 2: How many exam questions?
    By Clarksalinas in forum NETA Level 2 Exam
    Last Post: April 22, 2016, 06:21 PM
  2. Official NETA Level 2 Exam Most Missed Questions, Spring 2000
    Last Post: March 16, 2016, 08:18 PM
  3. Which NETA Standards are the questions based on?
    By Mjeelemco in forum NETA Level 2 Exam
    Last Post: July 17, 2015, 03:00 PM
  4. Replies: 1
    Last Post: June 17, 2015, 03:05 PM
