Results 1 to 6 of 6
Power systems around the globe
    Nov 2014
    17
    Color coded map shows different voltage/frequencies used across the world. Pretty neat.
    Reply •
  3. rizza_gay's Avatar
    rizza_gay is offline
    TTR Queen
    Jan 2016
    Philippines
    19
    Great info:)
    Quote Originally Posted by adamwilson View Post
    Philippines is also 220-240 V at 60Hz
    Reply •
    Mar 2016
    Can someoe explain why so many different types of systems and the advantages/disatvantages of each?
    Reply •
    Apr 2016
    Just be glad there is no color on there for DC.
    From personal experience (and ohms law) I know that 220-240V requires less amps (thus resulting in smaller wire) compared to 110-120V to push the same wattage.
    I also learned from experience with VFD's that 50HZ makes a 60HZ motor sound slow and 60HZ makes a 50HZ motor sound like it's in overdrive.
    Reply •
    Aug 2015
    15
    I've been told that if you were shocked 50hz it's less likely to cause ventricular fibrillation than 60hz because the 60hz is closer to your actual heart rate. Has anyone else heard this before?
    Reply •
    Apr 2016
    That's the first time I've ever heard that
    I wouldn't think that 3600 or 3000 cycles per minute make that much of a difference when comparing it to 60 to 120 bpm.
    Reply •
