Results 1 to 2 of 2
Cable hi-pot step voltage test
    Apr 2014
    61
    When testing HV cable with a DC hi-pot, how many of you raise your test voltage in steps each minute and record the values? This test is not specified in NETA from what I can tell but I notice some guys do it while others will just slowly bring up voltage and let it hold for 15 minutes. Does it make a difference one way or the other?
    Reply to Post •
    84
    It depends. Generally speaking I will do a step test when acceptance testing MV cable with a test voltage higher than 40 KV, or on a really long run. I do this only because you can trip the hipot with charging current if you bring up voltage to fast, doing the step test gives lets the leakage current settle before moving to the next step. Of course you want to always raise your voltage slowly anyway. For maintenance testing it is probably always a good idea to do the step test so you can predict if the cable will fail. Testing cable that has been in service for longer than 5 years can get sketchy.
    Reply to Post •
  1. Cable hi-pot withstanding time, why 15 minutes?
    Last Post: October 14, 2016, 08:58 AM
  2. Fall of Potential Test - Voltage/Resistance Rises Dramatically
    By BrickSalad in forum Electrical Testing Talk
    Last Post: December 12, 2015, 06:14 PM
  3. Regulated voltage for powering up test sets?
    By veracon0700 in forum Electrical Testing Talk
    Last Post: July 21, 2015, 07:16 PM
  4. Cable Insulation Precentage
    By CanTest in forum Electrical Testing Talk
    Last Post: June 24, 2014, 04:21 PM
