Results 1 to 6 of 6
Article: Basic Test Equipment: Insulation Resistance Tester
    Jun 2015
    Comments: Basic Test Equipment: Insulation Resistance Tester
    I spoke to a technician at the "Megger" manufacturing company and found the test needs to be at least 30 seconds in order to acheive a stable reading.
    Apr 2010
    558
  5. J2019L is offline Junior Member Pro Subscriber
    May 2014
    Seattle, WA
    You examine a test instrument commonly used to measure insulation resistance on equipment rated 600V or lower. The output of the test instrument is 1000 volts and the lead connections are?
    I don't understand the correct solution is none of the above. Is there any one can give an explanation?
  7. Varanjaya is offline Junior Member
    Sep 2019
    Why negative terminal connected to Line(conductor), positive to earth or body of conductor
  9. GDerr81 is offline Junior Member Pro Subscriber
    Jul 2015
    No Guard
    Note: Handheld megohmeters with outputs of 1000V or less may not be equipped with a Guard terminal.
    Quote Originally Posted by J2019L View Post
  11. Darker is offline Junior Member
    Sep 2020
    Quote Originally Posted by Varanjaya View Post
    Your question clarified my problem when I saw the diagram. L is the negative terminal and E is a positive terminal on the megger instrument. In real life, we do not deal with conventional current. The current flows from negative to positive hence Insulation is measured when leakage current flows from conductor to the Insulation.
  1. Insulation resistance test set question
  2. 230kV Auto-Transformer (Insulation Resistance Test)
    Last Post: January 19, 2018, 11:27 AM
  3. winding resistance tester and CPC 100
    Last Post: August 4, 2017, 12:09 PM
  4. Replies: 6
    Last Post: January 5, 2016, 02:09 PM
